Datasheet TL431LI, TL432LI (Texas Instruments) - 7
ОписаниеProgrammable Shunt Regulator with Optimized Reference Current
Страниц / Страница35 / 7 — TL431LI. TL432LI. www.ti.com. Typical Characteristics (continued). Figure …
Формат / Размер файлаPDF / 968 Кб
TL431LI. TL432LI. www.ti.com. Typical Characteristics (continued). Figure 7. Test Circuit for Voltage Amplification
TL431LI TL432LI www.ti.com Typical Characteristics (continued) Figure 7 Test Circuit for Voltage Amplification
38 предложений от 11 поставщиков
Микросхема: IC VREF SHUNT ADJ 0.5% SOT23-3
TL432LIBIDBZR
от 16 ₽
TL432LIBIDBZR
от 17 ₽
727GS
TL432LIBIDBZR
от 20 ₽
TL432LIBIDBZR
SLVSDQ6A – JULY 2018 – REVISED NOVEMBER 2018
75 200 IKA = 10 mA Gain T - dB A = 25°C Phase on ti 60 160 ica lif Output mp es A re 45 120 IKA 15 kΩ 232 Ω Deg oltage 30 80 9 µF al V + gn Phase - 15 40 − 8.25 kΩ - Small-Si V A 0 0 GND 100 1k 10k 100k 1M 10M f - Frequency - Hz Ga G in
Figure 7. Test Circuit for Voltage Amplification Figure 6. Small-Signal Voltage Amplification vs Frequency
100 1 kΩ IKA = 10 mA Output 50 ms TA = 25°C Oh 30 20 e - I c KA 10 dan 50 Ω 5 − 3 e Impe c 2 ren + e 1 ef GND R 0.5 | - A 0.3 K|Z 0.2 0.1 1k 10k 100k 1M f - Frequency - Hz D005
Figure 9. Test Circuit for Reference Impedance Figure 8. Reference Impedance vs Frequency
6 220 Ω T Input A = 25qC Output 5 - V ge 4 olta Pulse t V pu 3 Generator 50 Ω Output d Out f = 100 kHz 2 ut an Inp 1 GND 0 -1 0 1 2 3 4 5 6 7 t - Time - Ps puls
Figure 10. Pulse Response Figure 11. Test Circuit for Pulse Response
Copyright © 2018, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: TL431LI TL432LI Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Thermal Information 7.4 Recommended Operating Conditions 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Temperature Coefficient 8.2 Dynamic Impedance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) 9.4.2 Closed Loop 10 Applications and Implementation 10.1 Application Information 10.2 Typical Applications 10.2.1 Comparator With Integrated Reference 10.2.1.1 Design Requirements 10.2.1.2 Detailed Design Procedure 10.2.1.3 Application Curve 10.2.2 Precision Constant Current Sink 10.2.2.1 Design Requirements 10.2.2.2 Detailed Design Procedure 10.2.3 Shunt Regulator/Reference 10.2.3.1 Design Requirements 10.2.3.2 Detailed Design Procedure 10.2.3.3 Application Curve 10.2.4 Isolated Flyback with Optocoupler 10.2.4.1 Design Requirements 10.3 System Examples 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Related Links 13.2 Documentation Support 13.2.1 Device Nomenclature 13.2.2 Related Documentation 13.3 Receiving Notification of Documentation Updates 13.4 Community Resources 13.5 Trademarks 13.6 Electrostatic Discharge Caution 13.7 Glossary 14 Mechanical, Packaging, and Orderable Information
