Линейка продуктов KEEN SIDE
Datasheet TS432 (Taiwan Semiconductor) - 2
ПроизводительTaiwan Semiconductor
Описание1.24V Programmable Shunt Voltage Reference
Страниц / Страница9 / 2 — TS432. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. LIMIT. UNIT. Note:. …
Формат / Размер файлаPDF / 580 Кб
TS432. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. LIMIT. UNIT. Note:. RECOMMEND OPERATING CONDITION. ELECTRICAL SPECIFICATIONS
TS432 ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL LIMIT UNIT Note: RECOMMEND OPERATING CONDITION ELECTRICAL SPECIFICATIONS
6 предложений от 3 поставщиков
Three Terminal Voltage Reference, 1 Output, 1.24V, Trim/Adjustable, PDSO3, HALOGEN FREE AND ROHSCOMPLIANT, SOT-23, 3 PIN
TS432BCX-RFG
от 28 ₽
Элитан
TS432BCX-RFG
29 ₽
TS432BCXRFG
TS432
(TA = 25°C unless otherwise noted)
Cathode Voltage VKA 18 V Continuous Cathode Current IK 100 mA Reference Input Current IREF 3 mA Power Dissipation PD 0.35 W Junction Temperature TJ +150 oC Operation Temperature Range TOPER 0 ~ +70 oC Storage Temperature Range TSTG -65 ~ +150 oC
Note:
1: Voltage values are with respect to the anode terminal unless otherwise noted. 2: Rating apply to ambient temperature at 25oC
RECOMMEND OPERATING CONDITION PARAMETER SYMBOL LIMIT UNIT
Cathode Voltage (Note 1) VKA 16 V Continuous Cathode Current Range IK 100 mA
(TA=+25oC, unless otherwise specified)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNIT
VKA=VREF, IK=10mA TS432A 1.227 1.252 Reference voltage VREF 1.24 V (Figure 1) TS432B 1.233 1.246 Deviation of reference input V ∆ KA=VREF, IK=10mA (Figure 1) VREF -- 10 25 mV voltage TA=full range Radio of change in Vref to ∆VREF IKA=10mA, VKA=18V to VREF -- -1.0 -2.7 mV/V change in cathode Voltage /∆V (Figure 2) KA R1=10kΩ, R2=  Reference Input current IREF -- 0.25 0.5 µA IKA=10mA (Figure 2) Deviation of reference input R1=10kΩ, R2=  , I ∆ KA=10mA IREF -- 0.04 0.08 µA current, over temp. TA= full range (Figure 2) Off-state Cathode Current IKA(off) VREF =0V (Figure 3), VKA =18V -- 0.125 0.5 µA f<1kHz, V (Figure 1) KA=VREF Dynamic Output Impedance | ZKA | -- 0.2 0.4 Ω IKA=1mA to 100mA Minimum operating cathode IKA (min) VKA=VREF (Figure 1) -- 60 80 µA current
Note:
The deviation parameters ∆VREF and ∆IREF are defined as difference between the maximum value and minimum value obtained over the full operating ambient temperature range that applied. 2 Version: G2408
