Datasheet ATL431LI-Q1, ATL432LI-Q1 (Texas Instruments) - 8
ОписаниеHigh Bandwidth Low-IQ Programmable Shunt Regulator
Страниц / Страница37 / 8 — ATL431LI-Q1. ATL432LI-Q1. www.ti.com. Typical Characteristics (continued)
ATL431LI-Q1 ATL432LI-Q1 www.ti.com Typical Characteristics (continued)
40 предложений от 15 поставщиков
IC: источник опорного напряжения; 2,5В; ±1%; SOT23; бобина,лента
ATL432LIAQDBZRQ1
от 5.69 ₽
Рутоника
ATL432LIAQDBZRQ1
15 ₽
ATL432LIAQDBZRQ1
31 ₽
727GS
ATL432LIAQDBZRQ1
SNVSBB0A – MAY 2019 – REVISED NOVEMBER 2019
15 150 Ω A VKA = Vref 13 B VKA = 5 V IKA C VKA = 10 V Stable Region + 11 C V L BATT t - mA − en 9 e Curr od 7 ath TEST CIRCUIT FOR CURVE A - C 5 AIK 3 IKA R1 = 10 kΩ 150 Ω 1 0.001 0.01 0.1 1 10 C C L L - Load Capacitance - µF AT A L4 + The areas under the curves represent conditions that may cause the R2 VBATT device to oscillate. For curves B and C, R2 and V+ are adjusted to − establish the initial VKA and IKA conditions, with CL = 0. VBATT and CL then are adjusted to determine the ranges of stability.
Figure 13. Stability Boundary Conditions for All ATL431LI-
TEST CIRCUIT FOR CURVES B, C, AND D
Q1, ATL432LI-Q1 Devices Above 1 mA Figure 14. Test Circuit for Stability Boundary Conditions
150 Ω 1 A VKA = Vref B V I KA = 5 V KA C VKA = 10 V + 0.8 C V L BATT − t - mA en 0.6 e Curr od 0.4 TEST CIRCUIT FOR CURVE A ath - C A Stable Region I K 0.2 IKA R1 = 10 kΩ 150 Ω CL 0 + 0.001 0.01 0.1 1 10 R2 VBATT CL - Load Capacitance - µF ATL4 − The areas in-between the curves represent conditions that may cause the device to oscillate. For curves B and C, R2 and V+ are adjusted to establish the initial VKA and IKA conditions, with CL = 0. VBATT and TEST CIRCUIT FOR CURVES B, C, AND D CL then are adjusted to determine the ranges of stability.
Figure 15. Stability Boundary Conditions for All ATL431LI- Figure 16. Test Circuit for Stability Boundary Conditions Q1, ATL432LI-Q1 Devices Below 1 mA
8 Submit Documentation Feedback Copyright © 2019, Texas Instruments Incorporated Product Folder Links: ATL431LI-Q1 ATL432LI-Q1 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Temperature Coefficient 8.2 Dynamic Impedance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) 9.4.2 Closed Loop 10 Applications and Implementation 10.1 Application Information 10.2 Typical Applications 10.2.1 Comparator With Integrated Reference 10.2.2 Design Requirements 10.2.3 Detailed Design Procedure 10.2.3.1 Basic Operation 10.2.3.2 Output Voltage and Logic Input Level 10.2.4 Application Curves 10.2.5 Precision LED Lighting Current Sink Regulator 10.2.5.1 Design Requirements 10.2.5.2 Detailed Design Procedure 10.2.6 Shunt Regulator/Reference 10.2.6.1 Design Requirements 10.2.6.2 Detailed Design Procedure 10.2.6.3 Application Curves 10.2.7 Isolated Flyback with Optocoupler 10.2.7.1 Design Requirements 10.2.8 Adjustable Reference for Tracking LDO 10.2.8.1 Design Requirements 10.2.8.2 Detailed Design Procedure 10.3 System Examples 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Device Support 13.1.1 Device Nomenclature 13.2 Documentation Support 13.2.1 Related Documentation 13.3 Related Links 13.4 Receiving Notification of Documentation Updates 13.5 Support Resources 13.6 Trademarks 13.7 Electrostatic Discharge Caution 13.8 Glossary 14 Mechanical, Packaging, and Orderable Information
