Datasheet TSM1012 (STMicroelectronics) - 5
ПроизводительSTMicroelectronics
ОписаниеLow Consumption Voltage and Current Controller for Battery Chargers and Adaptors
Страниц / Страница14 / 5 — TSM1012. Electrical characteristics. Table 5. Electrical characteristics …
Формат / Размер файлаPDF / 284 Кб
TSM1012. Electrical characteristics. Table 5. Electrical characteristics (continued). Symbol. Parameter. Test condition. Min. Typ
TSM1012 Electrical characteristics Table 5 Electrical characteristics (continued) Symbol Parameter Test condition Min Typ
44 предложений от 19 поставщиков
Контроллера напряжения и тока для зарядного устройства, 4.5В до 28В, SO-8
TSM1012IDT
8.66 ₽
TSM1012IDT
79 ₽
TSM1012IDT
TSM1012IDT
TSM1012 Electrical characteristics Table 5. Electrical characteristics (continued) Symbol Parameter Test condition Min. Typ. Max. Unit
Reference input voltage deviation over the VCC Iload = 1 mA RegLine 20 mV range. Reference input voltage deviation over the VCC = 18 V, RegLoad 10 mV output current. 0 < Iload < 2.5 mA 1. Test conditions: pin 2 and 6 connected to GND, pin 4 and 5 connected to 1.25 V, pin 3 connected to 200 mV. 2. The current depends on the difference voltage between the negative and the positive inputs of the amplifier. If the voltage on the minus input is 1 mV higher than the positive amplifier, the sinking current at the output OUT will be increased by Gm x 1 mA. DocID10124 Rev 2 5/14 14 Document Outline Figure 1. Pin connections (top view) Table 1. Order codes 1 Pin descriptions Table 2. SO-8 pinout 2 Absolute maximum ratings Table 3. Absolute maximum ratings 3 Operating conditions Table 4. Operating conditions 4 Electrical characteristics Table 5. Electrical characteristics 5 Internal schematics Figure 2. Internal schematic Figure 3. Typical adapter or battery charger application using TSM1012 6 Principle of operation and application hints 6.1 Voltage and current control 6.1.1 Voltage control 6.1.2 Current control Figure 4. Output voltage versus output current 6.2 Compensation 6.3 Start-up and short-circuit conditions 6.4 Voltage clamp Figure 5. Clamp voltage Figure 6. Typical application schematic 7 Package information 7.1 SO-8 package information Figure 7. SO-8 package outline Table 6. SO-8 package mechanical data 8 Revision history Table 7. Document revision history
