Datasheet DS4305 (Analog Devices) - 3
ОписаниеElectronically Programmable Voltage Reference
Страниц / Страница8 / 3 — Electronically Programmable. Voltage Reference. DS4305. ELECTRICAL …
Формат / Размер файлаPDF / 308 Кб
Electronically Programmable. Voltage Reference. DS4305. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP
Electronically Programmable Voltage Reference DS4305 ELECTRICAL CHARACTERISTICS (continued) PARAMETER SYMBOL CONDITIONS MIN TYP
18 предложений от 9 поставщиков
DS4305R+T&R - Источник опорного напряжения - электронно программируемый, 4.0В - 5.5В, ±20мВ точность слежения
DS4305R+T&R
Maxim
167 ₽
727GS
DS4305R+T&R
Maxim
от 1 020 ₽
DS4305R+T
Maxim
DS4305R+T
Maxim
(VCC = +4.0V to +5.5V, TA = -40°C to +125°C, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
VOUT PSRR VOUTPSRR f = 200kHz 28 dB VOUT Self-Adjust Settling Time tST (Note 4) 7 10 ms/V EEPROM Programming Time tW (Note 5) 9 12 ms Turn-On Time tON VIN and ADJ = open circuit (Note 6) 10 µs ADJ Toggle Low Time tADJ 100 ns VOUT Factory-Trimmed Value VOUT FT +25°C, VCC = 5.8V (Note 7) 1200 mV
NONVOLATILE MEMORY CHARACTERISTICS
(VCC = +4.0V to 5.5V, unless otherwise noted.)
Programming Cycles +70°C (Note 8) 50,000 Cycles
Note 1:
All voltages referenced to ground.
Note 2:
Tracking accuracy is defined as VOUT - VIN after the DS4305 has completed self-adjustment.
Note 3:
Quantization refers to the size of the voltage steps used to track the input signal.
Note 4:
Settling time is the maximum amount of time VOUT requires to self-adjust. The settling time is determined by the following formula: ∆VOUT x tST.
Note 5:
EEPROM programming time is the hold time required after the DS4305 has completed self-adjustment before VIN or VCC can be removed or before ADJ can be toggled low once again.
Note 6:
Turn-on time is defined as the time required for VOUT to reach its specified accuracy after the required supply voltage is applied.
Note 7:
VOUT not loaded.
Note 8:
Guaranteed by design.
Typical Operating Characteristics
(VCC = 5.0V, TA = +25°C, unless otherwise noted.)
ACTIVE SUPPLY CURRENT ACTIVE SUPPLY CURRENT ACTIVE SUPPLY CURRENT vs. TEMPERATURE (VOUT = 0.3V) vs. TEMPERATURE (VOUT = 3.5V) vs. SUPPLY VOLTAGE (VOUT = 0.3V)
1.6 1.8 1.6 1.7 DS4305 toc01 1.5 DS4305 toc02 DS4305 toc03 1.5 TA = +125°C VCC = 5.0V 1.6 1.4 V T CC = 5.5V V 1.4 A = +85°C CC = 5.5V 1.5 1.3 VCC = 5.0V 1.3 1.4 1.2 V T CC = 4.0V VCC = 4.0V 1.2 A = +25°C SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 1.3 SUPPLY CURRENT (mA) T 1.1 A = -40°C 1.2 1.1 IL = 0mA ADJ = VCC IL = 0mA ADJ = VCC IL = 0mA 1.0 1.1 1.0 -40 -10 20 50 80 110 -40 -10 20 50 80 110 4.0 4.3 4.6 4.9 5.2 5.5 TEMPERATURE (°C) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
_____________________________________________________________________ 3
