Datasheet MAX6010 (Analog Devices) - 5
ОписаниеPrecision, Micropower, 3V Series Voltage Reference in SOT23
Страниц / Страница6 / 5 — Precision, Micropower, 3V Series. Voltage Reference in SOT23. MAX6010. …
Формат / Размер файлаPDF / 169 Кб
Precision, Micropower, 3V Series. Voltage Reference in SOT23. MAX6010. Typical Operating Characteristics (continued)
Precision, Micropower, 3V Series Voltage Reference in SOT23 MAX6010 Typical Operating Characteristics (continued)
38 предложений от 17 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
MAX6010AEUR+T
Maxim
от 58 ₽
MAX6010AEUR+T
Maxim
107 ₽
MAX6010AEUR+T
Maxim
243 ₽
Hi-Tech Circuit Group
MAX6010AEUR+T
(VIN = 5V, CIN = 0.1µF, COUT = 0.1µF. TA = +25°C, unless otherwise noted.)
LOAD-TRANSIENT RESPONSE LINE-TRANSIENT RESPONSE
MAX6010 toc13 MAX6010 toc14 -1mA VIN VIN 200mV/div 2V/div 7mA 4.8V VOUT 1V/div VOUT 10mV/div 400µs/div 400µs/div
Detailed Description Pin Description
The MAX6010 is a precision, low-noise, low-dropout, micropower, bandgap voltage reference in a SOT23
PIN NAME FUNCTION
package. This three-terminal reference operates with 1 IN Supply Voltage Input an input voltage from 3.2V to 5.5V, and outputs 3V. The Reference Voltage Output. Bypass with at device sources up to 7mA with < 200mV of dropout 2 OUT least 1nF to ground. (See the Output/Load voltage and requires only 5µA (max) supply current. Capacitance section.)
Applications Information
3 GND Ground
Output/Load Capacitance
The input voltage source must be capable of providing The MAX6010 requires a minimum of 1nF load to main- this current to ensure reliable turn-on. tain output stability.
Turn-On Time
The device remains stable for capacitive loads as high The MAX6010 typically turns on and settles to within as 1µF. In applications where the load or the supply 0.1% of the final value in 700µs. The turn-on time can can experience step changes, a larger output capaci- increase with the device operating at the minimum tor reduces the amount of overshoot (or undershoot) dropout voltage and the maximum load. and assists the circuit’s transient response.
Supply Current
The 5µA maximum supply current varies only 0.05µA/V with the supply voltage. When the supply voltage is below the minimum-speci- fied input voltage (as during turn-on), the device can draw up to 20µA beyond the nominal supply current.
_______________________________________________________________________________________ 5
