Datasheet MAX6069 (Analog Devices) - 6
Описание1μA WLP Precision Shunt Voltage Reference
Страниц / Страница9 / 6 — MAX6069. Pin Configuration. WLP. Pin Description. PIN. NAME. FUNCTION. …
Формат / Размер файлаPDF / 645 Кб
MAX6069. Pin Configuration. WLP. Pin Description. PIN. NAME. FUNCTION. Detailed Description. Output Voltage Hysteresis
MAX6069 Pin Configuration WLP Pin Description PIN NAME FUNCTION Detailed Description Output Voltage Hysteresis
MAX6069BAAWS+Tпо запросу
link to page 5 link to page 5
MAX6069
1μA Ultra-Tiny Shunt Voltage Reference
Pin Configuration
TOP VIEW (BUMPS ON BOTTOM)
MAX6069 +
OUT GND A1 A2 B1 B2 OUT GND
A1 OUT Output Voltage. Bias OUT with a pullup resistor to a potential greater than OUT. Bypass OUT to GND with a 0.01µF or larger capacitor. A2 GND Ground B1 OUT Output Voltage. B1 is shorted to A1 internally. B2 GND Ground. B2 is shorted to A2 internally.
The MAX6069 family consists of precision, two- Output voltage hysteresis is the change in the output terminal, shunt bandgap voltage references. On-chip, voltage at TA = +25°C before and after the device is cycled thin-film resistors are laser-trimmed to provide 0.2% output over its entire operating temperature range. Hysteresis is voltage accuracies. Voltages of +1.25V, +2.048V, +2.5V, caused by differential package stress appearing across and +3.0V are available in a space-saving 4-bump WLP. the bandgap core transistors. The temperature hysteresis value is typically less than 200ppm.
Applications Information Turn-On Time Output/Load Capacitance
The output capacitance and bias current of the MAX6069 Bypass OUT to GND with a 0.01μF or larger capacitor. greatly affect turn-on settling time. In the Typical Operating In applications where the load or the supply can experience Characteristics, turn-on time is shown with a 10nF out- step changes, additional capacitance will reduce the put capacitor and a 1.2μA bias current. Under these amount of overshoot (or undershoot) and assist the conditions, the MAX6069 settles in about 4ms. Settling circuit’s transient response. time linearly decreases in proportion to the circuit’s bias current. www.analog.com Analog Devices │ 6
