Datasheet REF20-Q1 (Texas Instruments) - 9
ОписаниеLow-Drift, Low-Power, Dual-Output, VREF and VREF / 2 Voltage References
Страниц / Страница36 / 9 — REF20-Q1. www.ti.com. 7.6 Typical Characteristics (continued). Figure …
Формат / Размер файлаPDF / 3.4 Мб
REF20-Q1. www.ti.com. 7.6 Typical Characteristics (continued). Figure 7-13. Load Regulation Sourcing vs Temperature (VREF)
REF20-Q1 www.ti.com 7.6 Typical Characteristics (continued) Figure 7-13 Load Regulation Sourcing vs Temperature (VREF)
23 предложений от 7 поставщиков
Voltage References Automotive low-drift, low-power, series voltage reference
REF2041QDDCRQ1
от 76 ₽
REF2041QDDCRQ1
278 ₽
Зенер
Россия и страны ТС
REF2041QDDCRQ1
от 338 ₽
REF2041QDDCRQ1
459 ₽
REF20-Q1 www.ti.com
SBOSA80 – DECEMBER 2021
At TA = 25°C, IL = 0 mA, VIN = 5 V power supply, CL = 0 µF, and 2.5 V output, unless otherwise noted. 12 ) 12 ) A A /m 11 /m 11 m m p p 10 (p 10 (p g g in in rc 9 rc 9 u u o o S 8 S 8 n n tio tio la 7 la 7 u u g g e e 6 6 R R d d a a o 5 o 5 L - L - F S E 4 IA 4 R B V ±75 ±50 ±25 0 25 50 75 100 125 150 V ±75 ±50 ±25 0 25 50 75 100 125 150 Temperature (ƒC) Temperature ( C025 ƒC) C020 VREF output IL = 20 mA VBIAS output IL = 20 mA
Figure 7-13. Load Regulation Sourcing vs Temperature (VREF) Figure 7-14. Load Regulation Sourcing vs Temperature (VBIAS)
12 ) 12 ) A A /m 11 /m 11 m m p p 10 10 (p (p g g in in k 9 k 9 in in S S n 8 n 8 tio tio la la 7 u u 7 g g e e R 6 R 6 d d a a o o 5 5 - L - L F S E IA R 4 B 4 V V ±75 ±50 ±25 0 25 50 75 100 125 150 ±75 ±50 ±25 0 25 50 75 100 125 150 Temperature (ƒC) C021 Temperature (ƒC) C022 VREF output IL = –20 mA VBIAS output IL = –20 mA
Figure 7-15. Load Regulation Sinking vs Temperature (VREF) Figure 7-16. Load Regulation Sinking vs Temperature (VBIAS)
5 5 ) 4.5 /V 4.5 /V m m p p (p 4 (p 4 n n tio tio la la u 3.5 u 3.5 g g e e R R e 3 e in 3 in L L F S E IA R B V 2.5 2.5 V 2 2 ±75 ±50 ±25 0 25 50 75 100 125 150 ±75 ±50 ±25 0 25 50 75 100 125 150 Temperature (ƒC) C019 Temperature (ƒC) C018 VREF output VBIAS output
Figure 7-17. Line Regulation vs Temperature (VREF) Figure 7-18. Line Regulation vs Temperature (VBIAS)
Copyright © 2021 Texas Instruments Incorporated Submit Document Feedback 9 Product Folder Links: REF20-Q1 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Solder Heat Shift 8.2 Long-Term Stability 8.3 Thermal Hysteresis 8.4 Noise Performance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.3.1 VREF and VBIAS Tracking 9.3.2 Low Temperature Drift 9.3.3 Load Current 9.4 Device Functional Modes 10 Applications and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Low-Side, Current-Sensing Application 10.2.1.1 Design Requirements 10.2.1.2 Detailed Design Procedure 10.2.1.2.1 Shunt Resistor 10.2.1.2.2 Differential Amplifier 10.2.1.2.3 Voltage Reference 10.2.1.2.4 Error Calculations 10.2.1.2.5 Application Curves 11 Power-Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Documentation Support 13.1.1 Related Documentation 13.2 Receiving Notification of Documentation Updates 13.3 Support Resources 13.4 Trademarks 13.5 Electrostatic Discharge Caution 13.6 Glossary 14 Mechanical, Packaging, and Orderable Information
