Datasheet REF2025, REF2030, REF2033, REF2041 (Texas Instruments) - 6
Описание | Low-Drift, Low-Power, Dual-Output, VREF and VREF / 2 Voltage References |
Страниц / Страница | 35 / 6 — REF2025. , REF2030, REF2033, REF2041. www.ti.com. 7.6 Typical … |
Формат / Размер файла | PDF / 3.9 Мб |
Язык документа | английский |
REF2025. , REF2030, REF2033, REF2041. www.ti.com. 7.6 Typical Characteristics. Figure 7-1. Initial Accuracy Distribution (VREF)
32 предложений от 14 поставщиков Источник опорного напряжения, маленький дрейф, малой мощности, двойной выход, REF2025, 2.5В |
| REF2025AIDDCT Texas Instruments | от 83 ₽ | |
| REF2025AIDDCT Texas Instruments | 112 ₽ | |
| REF2025AIDDCT Texas Instruments | 120 ₽ | |
| REF2025AIDDCT Texas Instruments | 982 ₽ | |
REF2025 , REF2030, REF2033, REF2041
SBOS600E – JULY 2018 – REVISED FEBRUARY 2022
www.ti.com 7.6 Typical Characteristics
At TA = 25°C, IL = 0 mA, VIN = 5-V power supply, CL = 0 µF, and 2.5-V output, unless otherwise noted. 70 50 60 40 50 (%) (%) 30 n 40 n tio tio la la u 30 u p p o 20 o P P 20 10 10 0 5 4 3 2 1 0 1 2 3 4 5 0 .0 .0 .0 .0 .0 .0 .0 .0 .0 .0 0 1 2 3 4 5 6 7 8 -0 -0 -0 -0 -0 0 0 0 0 0 VREF Drift Distribution (ppm/ƒC) V Initial Accuracy (%) REF C010 C015
–40°C ≤ TA ≤ 125°C
Figure 7-2. Drift Distribution (VREF)
80 50 70 40 60 50 (%) (%) 30 n n tio 40 tio la la u u p p o 30 20 o P P 20 10 10 0 5 4 3 2 1 0 1 2 3 4 5 0 .0 .0 .0 .0 .0 .0 .0 .0 .0 .0 0 1 2 3 4 5 6 7 8 -0 -0 -0 -0 -0 0 0 0 0 0 VBIAS Drift Distribution (ppm/ƒC) V Initial Accuracy (%) BIAS C008 C015
Figure 7-3. Initial Accuracy Distribution (VBIAS)
–40°C ≤ TA ≤ 125°C
Figure 7-4. Drift Distribution (VBIAS)
40 60 50 30 40 (%) (%) n n tio 20 tio 30 la la u u p p o o P P 20 10 10 0 0 0 0 0 0 0 0 0 0 0 0 0 8 6 4 2 2 4 6 8 0 1 2 3 4 5 6 1 ± ± ± ± ± V and V Tracking Over Temperature (ppm/ REF BIAS ƒC) V and V Matching (ppm) REF BIAS C004 C016
Figure 7-5. VREF – 2 × VBIAS Distribution
–40°C ≤ TA ≤ 85°C
Figure 7-6. Distribution of VREF – 2 × VBIAS Drift Tracking Over Temperature
6 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: REF2025 REF2030 REF2033 REF2041 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions Pin Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Solder Heat Shift 8.2 Long-Term Stability 8.3 Thermal Hysteresis 8.4 Noise Performance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.3.1 VREF and VBIAS Tracking 9.3.2 Low Temperature Drift 9.3.3 Load Current 9.4 Device Functional Modes 10 Applications and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Low-Side, Current-Sensing Application 10.2.1.1 Design Requirements 10.2.1.2 Detailed Design Procedure 10.2.1.2.1 Shunt Resistor 10.2.1.2.2 Differential Amplifier 10.2.1.2.3 Voltage Reference 10.2.1.2.4 Results 10.2.1.3 Application Curves 11 Power-Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Documentation Support 13.1.1 Related Documentation 13.2 Receiving Notification of Documentation Updates 13.3 Support Resources 13.4 Trademarks 13.5 Electrostatic Discharge Caution 13.6 Glossary 14 Mechanical, Packaging, and Orderable Information
