Линейка продуктов KEEN SIDE
Datasheet LM389 (National Semiconductor) - 8
ПроизводительNational Semiconductor
ОписаниеLM389 Low Voltage Audio Power Amplifier with NPN Transistor Array
Страниц / Страница8 / 8 — Application. Hints. (Continued). Array. Transistor. NPN. with. TL/H/7847. …
Формат / Размер файлаPDF / 211 Кб
Application. Hints. (Continued). Array. Transistor. NPN. with. TL/H/7847. –. 12. FIGURE. 7. Noise. Generator. Using. Zener. Diode. Amplifier. Physical
Application Hints (Continued) Array Transistor NPN with TL/H/7847 – 12 FIGURE 7 Noise Generator Using Zener Diode Amplifier Physical
LifeElectronics
LM389N-1
ТаймЧипс
LM389N
LM389N
LM389
Application Hints (Continued) Array Transistor NPN with TL/H/7847 – 12 FIGURE 7. Noise Generator Using Zener Diode Amplifier Physical Dimensions inches (millimeters) Power Molded Dual-In-Line Package (N) Audio Order Number LM389N NS Package Number N18A Voltage Low LM389 LIFE SUPPORT POLICY NATIONAL’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF NATIONAL SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or 2. A critical component is any component of a life systems which, (a) are intended for surgical implant support device or system whose failure to perform can into the body, or (b) support or sustain life, and whose be reasonably expected to cause the failure of the life failure to perform, when properly used in accordance support device or system, or to affect its safety or with instructions for use provided in the labeling, can effectiveness. be reasonably expected to result in a significant injury to the user. National Semiconductor National Semiconductor National Semiconductor National Semiconductor Corporation Europe Hong Kong Ltd. Japan Ltd. 1111 West Bardin Road Fax: (a49) 0-180-530 85 86 13th Floor, Straight Block, Tel: 81-043-299-2309 Arlington, TX 76017 Email: cnjwge @ tevm2.nsc.com Ocean Centre, 5 Canton Rd. Fax: 81-043-299-2408 Tel: 1(800) 272-9959 Deutsch Tel: (a49) 0-180-530 85 85 Tsimshatsui, Kowloon Fax: 1(800) 737-7018 English Tel: (a49) 0-180-532 78 32 Hong Kong Fran3ais Tel: (a49) 0-180-532 93 58 Tel: (852) 2737-1600 Italiano Tel: (a49) 0-180-534 16 80 Fax: (852) 2736-9960 National does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and National reserves the right at any time without notice to change said circuitry and specifications.
