Datasheet VOFD341A (Vishay) - 3
ПроизводительVishay
Описание3 A Output Current IGBT and MOSFET Driver
Страниц / Страница12 / 3 — VOFD341A. RECOMMENDED OPERATING CONDITION PARAMETER. SYMBOL. MIN. MAX. …
Формат / Размер файлаPDF / 225 Кб
VOFD341A. RECOMMENDED OPERATING CONDITION PARAMETER. SYMBOL. MIN. MAX. UNIT. Note. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION
VOFD341A RECOMMENDED OPERATING CONDITION PARAMETER SYMBOL MIN MAX UNIT Note ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION
5 предложений от 2 поставщиков
Элитан
VOFD341A-X018T
145 ₽
VOFD341A-X018T
от 170 ₽
VOFD341A
www.vishay.com Vishay Semiconductors
RECOMMENDED OPERATING CONDITION PARAMETER SYMBOL MIN. MAX. UNIT
Operating temperature Tamb -40 +125 °C Power supply voltage VCC - VEE 15 30 V Forward current (VO in “high” state) (1) IF(ON) 8 16 mA Forward voltage (VO in “low” state) VF(OFF) -3.0 0.8 V Operating frequency f 0 75 kHz
Note
(1) The rise and fall times of the input on-current should be less than 0.5 μs
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT INPUT
Forward voltage IF = 10 mA VF 1.2 1.37 1.8 V Temperature coefficient I of forward voltage F = 10 mA ΔVF/ΔT - -2.0 - mV/°C Reverse breakdown voltage IR = 10 μA BVR 5 - - V Threshold forward current V (V CC = 30 V, VO < 5 V IFLH - 2.5 5 mA O from “low” to “high”) Threshold forward voltage V (V CC = 30 V, VO > 5 V VFLH 0.8 - - V O from “high” to “low”) Input capacitance f = 1 MHz, VF = 0 V CIN - 33 - pF
OUTPUT
High level supply current IF = 10 mA, VCC = 30 V, VO = open ICCH - 1.7 3.0 mA Low level supply current IF = 0 mA, VCC = 30 V, VO = open ICCL - 2.0 3.0 mA VO = (VCC - 1.5 V) IOH (1) - - -1.0 A High level output current VO = (VCC - 4 V) IOH (2) - - -2.5 A VO = (VEE + 1.5 V) IOL (1) 1.0 - - A Low level output current VO = (VEE + 4 V) IOL (2) 2.5 - - A High level output voltage IF = 10 mA, IO = -100 mA VOH VCC - 0.3 V VCC - 0.1 V - V Low level output voltage IF = 0 mA, IO = 100 mA VOL - VEE + 0.1 V VEE + 0.25 V V VO > 5 V, IF = 10 mA VUVLO+ 11.0 12.7 13.5 V UVLO threshold VO < 5 V, IF = 10 mA VUVLO- 9.5 11.2 12.0 V UVLO hysteresis UVLOHYS - 1.5 - V
COUPLER
Input to output capacitance f = 1 MHz CIO - 0.92 - pF
Notes
• All typical values at Tamb = 25°C and VCC - VEE = 30 V, unless otherwise specified; all minimum and maximum specifications are at recommended operating condition (1) Maximum pulse width = 50 μs (2) Maximum pulse width = 10 μs Rev. 1.0, 20-Jun-2024
3
Document Number: 80420 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
