Data Brief Teseo-VIC6A (STMicroelectronics) - 3
ПроизводительSTMicroelectronics
ОписаниеAutomotive Quad-bands GNSS Module With 6-axis IMU
Страниц / Страница8 / 3 — Teseo-VIC6A. Module description. 1.3. Pin out description. Table 1. …
Формат / Размер файлаPDF / 343 Кб
Teseo-VIC6A. Module description. 1.3. Pin out description. Table 1. Module pin out description. Number. Name. I/O. Description. DB5477
Teseo-VIC6A Module description 1.3 Pin out description Table 1 Module pin out description Number Name I/O Description DB5477
35 предложений от 14 поставщиков
GPS Receiver 1575.42MHz 4.3V Automotive 18-Pin LLCC T/R
Зенер
Россия и страны ТС
TESEO-LIV3R
от 579 ₽
TESEO-LIV3R
921 ₽
ЧипСити
TESEO-LIV3R
1 022 ₽
TESEO-LIV3R
Teseo-VIC6A Module description 1.3 Pin out description Table 1. Module pin out description Number Name I/O Description
1 Wake-up I External interrupt pin (if not used, must be left floating) 2 Reserved Reserved 3 PPS O Time pulse (PPS) 4 WHEELTICK I DRAW wheel tick signal 5 Reserved I Reserved 6 IRQ O IRQ 7 Reserved NC 8 nReset I Input signal to force the module to reset 9 VCC_RF O Output voltage RF section. It can be used to supply an external active antenna 10 GND Ground Ground 11 RF_IN I GNSS signal input 12 GND Ground Ground 13 GND Ground Ground 14 Ant_OFF O External antenna control 15 FWD I DRAW Forward signal 16 Reserved Reserved 17 Reserved Reserved 18 I2C_SDA I/O I2C-Data 19 I2C_SCL I/O I2C-Clock 20 UART-TX O UART-TX 21 UART-RX I UART-RX 22 V_BAT I Backup voltage supply 23 VCC I Supply voltage 24 GND Ground Ground
DB5477
Rev 2 page 3/8
Document Outline Teseo-VIC6A 1 Module description 1.1 Block diagram 1.2 Pin configuration 1.3 Pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 2.4 Galileo 2.5 IRNSS 2.6 QZSS 3 Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS Revision history
