Data Brief Teseo-VIC6A (STMicroelectronics) - 5
ПроизводительSTMicroelectronics
ОписаниеAutomotive Quad-bands GNSS Module With 6-axis IMU
Страниц / Страница8 / 5 — Teseo-VIC6A. Augmentation systems. 3.1. Satellite-based augmentation …
Формат / Размер файлаPDF / 343 Кб
Teseo-VIC6A. Augmentation systems. 3.1. Satellite-based augmentation system. 3.2. Differential GPS. DB5477. Rev 2. page 5/8
Teseo-VIC6A Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS DB5477 Rev 2 page 5/8
35 предложений от 14 поставщиков
GPS Receiver 1575.42MHz 4.3V Automotive 18-Pin LLCC T/R
TESEO-LIV3F
от 252 ₽
TESEO-LIV3F
559 ₽
Зенер
Россия и страны ТС
TESEO-LIV3R
от 579 ₽
TESEO-LIV3F
2 902 ₽
Teseo-VIC6A Augmentation systems 3 Augmentation systems 3.1 Satellite-based augmentation system
The module supports SBAS. SBAS is a wide area differential GPS (WADGPS), it is a system which provides differential GPS corrections data; SBAS includes the WAAS within the United States, the EGNOS within Europe, the multifunctional transport satellite (MTSAT) – based MSAS within Japan and southeast Asia, and the GPS and GEO augmented navigation (GAGAN) system in India. SBAS data correction is used in the GNSS algorithm to provide a better position estimation. The overall SBAS differential correction mechanism can be conceived as built in 2 phases: • The “acquire and tracking” phase • The “decoding” phase The “acquire and track” phase relates to the capacity of the acquisition engine to reliably track the configured SBAS satellite; during the decoding phase the SBAS message can be decoded to fetch the differential corrections. The current longitude limits for each service are: • WAAS -180°C to -25°C • EGNOS -25°C to +50°C • GAGAN +50°C to +100°C • MSAS +100°C to +180°C The module software with SBAS capability implements a command interface at the NMEA level to allow interaction with the SBAS library. It supports commands to enable/disable the SBAS functionality.
The module supports differential-GPS data according to RTCM 2.3 (radio technical commission for maritime services). Differential-GPS data improves position accuracy.
DB5477
Rev 2 page 5/8
Document Outline Teseo-VIC6A 1 Module description 1.1 Block diagram 1.2 Pin configuration 1.3 Pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 2.4 Galileo 2.5 IRNSS 2.6 QZSS 3 Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS Revision history
