Datasheet FL7740 (ON Semiconductor) - 2
| Производитель | ON Semiconductor |
| Описание | Constant-Voltage Primary-Side-Regulation PWM Controller for Power Factor Correction |
| Страниц / Страница | 15 / 2 — FL7740. BLOCK DIAGRAM. VOUT.MAIN. Secondary. DC−DC. Converter. Dimming. … |
| Формат / Размер файла | PDF / 422 Кб |
FL7740. BLOCK DIAGRAM. VOUT.MAIN. Secondary. DC−DC. Converter. Dimming. Signal. VDD. OUT.BIAS. GND. Control. GATE. COMV. Module. BIAS. 0−10, DALI,
44 предложений от 15 поставщиков ШИМ контроллер, постоянное напряжение, первичной стороны, 90В - 305В AC вход, 65кГц, 5мА, NSOIC-10 |
| FL7740MX ON Semiconductor | 38 ₽ | |
| FL7740MX ON Semiconductor | 52 ₽ | |
| FL7740MX ON Semiconductor | от 105 ₽ | |
| FL7740MX ON Semiconductor | от 153 ₽ | |
FL7740 BLOCK DIAGRAM VOUT.MAIN V Secondary AC DC−DC Converter Dimming FL7740 Signal V VDD HV OUT.BIAS Dimming GND NC Control GATE COMV Module CS BIAS 0−10, DALI, Wireless, etc. VS PF Figure 1. Application Schematic Dynamic control GND VDYN−REF1,2,3 HV GM amp. VREF V NC VS EAV JFET S/H VDD COMV Gain control at startup Digital Duty Control Driver GATE BIAS 5V regulator VIN.PK Protection CS VOUT open/short protection PF Digital PF RCS open/short protection VDD optimizer Over current protection Over load protection EAV V Thermal shutdown C DYN−REF PF detector control Shutdown Figure 2. Simplified Block Diagram www.onsemi.com 2
