Datasheet NCL30001 (ON Semiconductor) - 3
ПроизводительON Semiconductor
ОписаниеHigh-Efficiency Single Stage Power Factor Correction and Step-Down Offline LED Driver
Страниц / Страница33 / 3 — NCL30001. PIN FUNCTION DESCRIPTION. Pin. Symbol. Description. …
Формат / Размер файлаPDF / 405 Кб
NCL30001. PIN FUNCTION DESCRIPTION. Pin. Symbol. Description. www.onsemi.com
NCL30001 PIN FUNCTION DESCRIPTION Pin Symbol Description www.onsemi.com
47 предложений от 19 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
NCL30001DR2G
от 38 ₽
ЧипСити
NCL30001DR2G
105 ₽
NCL30001DR2G
239 ₽
NCL30001DR2G
link to page 29
1 CT An external timing capacitor (CT) sets the oscillator frequency. A sawtooth between 0.2 V and 4 V sets the oscillator frequency and the gain of the multiplier. 2 RAMP COMP A resistor (RRC) between this pin and ground adjust the amount of ramp compensation that is added to the current signal. Ramp compensation is required to prevent subharmonic oscillations. This pin should not be left open. 3 AC IN The scaled version of the full wave rectified input ac wave is connected to this pin by means of a resistive voltage divider. The line voltage information is used by the multiplier. 4 FB An error signal from an external error amplifier circuit is fed to this pin via an optocoupler or other isolation circuit. The FB voltage is a proportional of the load of the converter. If the voltage on the FB pin drops below 0.41 V (typical) the controller enters Soft−Skip to reduce acoustic noise. 5 VFF Feedforward input. A scaled version of the filtered rectified line voltage is applied by means of a resistive divider and an averaging capacitor. The information is used by the Reference Generator to regulate the controller. 6 CM Multiplier output. A capacitor is connected between this pin and ground to filter the modulated output of the multiplier. 7 AC COMP Sets the pole for the ac reference amplifier. The reference amplifier compares the low frequency component of the input current to the ac reference signal. The response must be slow enough to filter out most of the high frequency content of the current signal that is injected from the current sense amplifier, but fast enough to cause minimal distortion to the line frequency information. The pin should not be left open. 8 Latch Latch−Off input. Pulling this pin below 1.0 V (typical) or pulling it above 7.0 V (typical) latches the controller. This input can be used to implement an overvoltage detector, an overtemperature detector or both. Refer to Figure 60 for a typical implementation. 9 TEST This pin is a TEST pin. A nominal 50K $10% resistor must be connected to GND for proper operation. 10 IAVG An external resistor and capacitor connected from this terminal to ground, to set and stabilizes the gain of the current sense amplifier output that drives the ac error amplifier. 11 ISpos Positive current sense input. Connects to the positive side of the current sense resistor. 12 VCC Positive input supply. This pin connects to an external capacitor for energy storage. An internal current source supplies current from the STARTUP pin VCC. Once the voltage on VCC reaches approximately 15.3 V, the current source turns off and the outputs are enabled. The drivers are disabled once VCC reaches approximately 10.2 V. If VCC drops below 0.83 V (typical), the startup current is reduced to less than 500 mA. 13 DRV Drive output for the main flyback power MOSFET or IGBT. DRV has a source resistance of 10.8 W (typical) and a sink resistance of 8 W (typical). 14 NC No Connect 15 GND Ground reference for the circuit. 16 HV Connect the rectified input line voltage directly to this pin to enable the internal startup regulator. A constant current source supplies current from this pin to the capacitor connected to the VCC pin, eliminating the need for a startup resistor. The charge current is typically 5.5 mA. Maximum input voltage is 500 V.
www.onsemi.com 3
