Datasheet NCL30001 (ON Semiconductor) - 4
ПроизводительON Semiconductor
ОписаниеHigh-Efficiency Single Stage Power Factor Correction and Step-Down Offline LED Driver
Страниц / Страница33 / 4 — NCL30001. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. www.onsemi.com
Формат / Размер файлаPDF / 405 Кб
NCL30001 MAXIMUM RATINGS Rating Symbol Value Unit www.onsemi.com
38 предложений от 16 поставщиков
Драйвер LED , ON SEMICONDUCTOR NCL30001DR2G Led Driver, 1 Output, Constant Current, 6V in, 100kHz switch, SOIC-16
727GS
NCL30001DR2G
от 50 ₽
NCL30001DR2G
81 ₽
NCL30001DR2G
от 112 ₽
NCL30001DR2G
165 ₽
(Notes 1 and 2)
Start_up Input Voltage VHV −0.3 to 500 V Start_up Input Current IHV $100 mA Power Supply Input Voltage VCC −0.3 to 20 V Power Supply Input Current ICC $100 mA Latch Input Voltage VLatch −0.3 to 10 V Latch Input Current ILatch $100 mA All Other Pins Voltage −0.3 to 6.5 V All Other Pins Current $100 mA Thermal Resistance, Junction−to−Air qJA C/W 0.1 in” Copper 130 0.5 in” Copper 110 Thermal Resistance, Junction−to−Lead RΘJL 50 C/W Maximum Power Dissipation @ TA = 25C PMAX 0.77 W Operating Temperature Range TJ −40 to 125 C Storage Temperature Range TSTG −55 to 150 C Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. 1. This device contains ESD protection and exceeds the following tests: Pin 1−15: Human Body Model 2000 V per JEDEC Standard JESD22, Method A114E. Machine Model Method 200 V per JEDEC Standard JESD22, Method A114A. Pin 16 is the high voltage startup of the device and is rated to the maximum rating of the part, 500 V. 2. This device contains Latchup protection and exceeds 100 mA per JEDEC Standard JESD78.
www.onsemi.com 4
