Линейка продуктов KEEN SIDE
Datasheet MXO45, MXO4T, MXO45HS, MXO45HST (CTS Electronic Components) - 5
ПроизводительCTS Electronic Components
ОписаниеHCMOS/TTL Clock Oscillators
Страниц / Страница5 / 5 — MXO45. &. MXO45HS. HCMOS/TTL. Clock. Oscillators. Packaging. -. CTS. …
Формат / Размер файлаPDF / 383 Кб
MXO45. &. MXO45HS. HCMOS/TTL. Clock. Oscillators. Packaging. -. CTS. Approved. Methods. Anti-Static. Foam. in. Cardboard. Carton. Typical. packing
MXO45 & MXO45HS HCMOS/TTL Clock Oscillators Packaging - CTS Approved Methods Anti-Static Foam in Cardboard Carton Typical packing
MXO45HS-5C
MXO45
MXO45HS
MXO45HST
MXO45T
MXO45 & MXO45HS HCMOS/TTL Clock Oscillators Packaging - CTS Approved Methods Anti-Static Foam in Cardboard Carton Typical packing format: 1. 50pcs. per anti-static foam layer. 2. 2 layers of anti-static foam [100pcs.] per inner cardboard carton. Carton size is approximately 170mm x 120mm x 45mm [LxWxH]. 3. An anti-static foam sheet layer is placed as a buffer on top of each layer containing oscillators. 4. Master-pack multiple inner cartons in a larger outer cardboard carton. 20 inner cartons [100pcs. per carton] per outer carton, is approximately 550mm x 350mm x 180mm [LxWxH]. Anti-Static Plastic Trays Typical packing format: 1. 50pcs. per plastic tray. Tray size is approximately 180mm x 136mm x 18mm [LxWxH]. 2. 2 trays per anti-static bag [100pcs.] or 10 trays per anti-static bag [500pcs.] Bag height for 10 trays is approximately 175mm. 3. One anti-static bag per inner cardboard carton. 4. Master-pack multiple inner cartons in a larger outer cardboard carton. 8 inner cartons [10 trays per carton] per outer carton, is approximately 460mm x 380mm x 400mm [LxWxH]. Anti-Static Plastic Tubes Typical packing format: 1. 10pcs. per plastic tube – Full-Size package. 15pcs. per plastic tube – Half-Size package. 2. Plastic tubes are master packed in cardboard carton. Carton is approximately 35mm x 35mm x 20mm [LxWxH]. DOC# 008-0258-0 Rev. M Page 5 of 5 ©2017 CTS® Corporation. Information/product(s) subject to change. No warranty that product(s) will meet the stated specifications for customer specific applications or test equipment. Visit www.ctscorp.com for list of applicable patent(s), more information, or to request a quote.
