Datasheet DS1801 (Analog Devices) - 2
ОписаниеDual Audio Taper Potentiometer
Страниц / Страница10 / 2 — OPERATION. RESISTANCE CHARACTERISTICS. POSITION. OUTPUT LEVEL (dB). …
Формат / Размер файлаPDF / 235 Кб
OPERATION. RESISTANCE CHARACTERISTICS. POSITION. OUTPUT LEVEL (dB). DS1801 BLOCK DIAGRAM
OPERATION RESISTANCE CHARACTERISTICS POSITION OUTPUT LEVEL (dB) DS1801 BLOCK DIAGRAM
48 предложений от 27 поставщиков
Энергозависимый цифровой потенциометр, 45 кОм, Двойной, 3-проводной, Последовательный
Элитан
DS1801S+
270 ₽
Триема
DS1801E-014 х микросхема
1 733 ₽
ЗУМ-СМД
DS1801
Maxim
DS1801S
Maxim
DS1801
OPERATION
The DS1801 provides two 65-position potentiometers per package, each having a logarithmic resistive characteristic as shown in Table 1. The DS1801 is controlled by a 3-wire serial interface. The 3-wire serial interface is designed for CPU-controlled applications and allows the potentiometer’s exact wiper position to be read or written. The DS1801 design supports daisy-chaining for multi-device environments. Figure 1 presents a block diagram of the DS1801. As shown, the inputs from the 3-wire serial interface drive a command/control unit. The command/control unit interprets these inputs for control of the two potentiometers. On power-up, the serial port is stable and active within 10 microseconds. The wiper position on power-up will be at position 63, the low end of the potentiometer. Position 64 is the mute level.
Table 1
0 0 1 -1 2 -2 3 -3 4 -4 5 -5 63 -63 64(mute) <-90
Figure 1 2 of 10
