Datasheet MAX873, MAX875, MAX876 (Analog Devices) - 3
ОписаниеLow-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage Reference
Страниц / Страница12 / 3 — Low-Power, Low-Drift, +2.5V/+5V/+10V. Precision Voltage References. …
Формат / Размер файлаPDF / 388 Кб
Low-Power, Low-Drift, +2.5V/+5V/+10V. Precision Voltage References. MAX873/MAX875/MAX876
Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References MAX873/MAX875/MAX876
39 предложений от 21 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
MAX873AESA+T
Maxim
290 ₽
ЧипСити
MAX873AESA+T
Maxim
543 ₽
727GS
MAX873AESA-T
Maxim
Hi-Tech Circuit Group
MAX873AESA+T
Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References MAX873/MAX875/MAX876 ELECTRICAL CHARACTERISTICS—MAX875 (continued)
(VIN = +15V, IL = 0mA, CLOAD < 100pF, TA = -40°C to +85°C, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
I TA = +25°C 3 15 L = 0 to 10mA (source) TA = -40°C to +85°C 3 20 Load Regulation ppm/mA TA = +25°C 100 900 IL = 0 to -1mA (sink) TA = -40°C to +85°C 150 1900 TA = +25°C 320 550 Quiescent Supply Current IQ µA TA = -40°C to +85°C 320 700 Short-Circuit Output Current ISC Output shorted to GND 60 mA VOUT Adjust Range ±300 mV Long-Term Output Drift 50 ppm/kh
TEMP PIN
Voltage Output VTEMP TA = +25°C 630 mV Temperature Sensitivity TCVTEMP 2.1 mV/°C
ELECTRICAL CHARACTERISTICS—MAX876
MAX876A (0.03%) 9.997 10.000 10.003 Output Voltage VOUT TA = +25°C V MAX876B (0.05%) 9.995 10.000 10.005 Output Voltage Drift MAX876A 2 7 TCVOUT ppm/°C (Note 1) MAX876B 5 20 0.1Hz to 10Hz 18 µVP-P Output-Noise Voltage en TA = +25°C 10Hz to 1kHz 29 µVRMS TA = +25°C 1 4.0 Line Regulation VIN = 12V to 18V ppm/V TA = -40°C to +85°C 1 6 I TA = +25°C 1 15 L = 0 to 10mA (source) TA = -40°C to +85°C 1 20 Load Regulation ppm/mA TA = +25°C 100 900 IL = 0 to -1mA (sink) TA = -40°C to +85°C 150 1900 TA = +25°C 320 550 Quiescent Supply Current IQ µA TA = -40°C to +85°C 340 700 Short-Circuit Output Current ISC Output shorted to GND 60 mA VOUT Adjust Range ±600 mV Long-Term Output Drift 50 ppm/kh
TEMP PIN
Note 1:
Temperature coefficient is defined as maximum ∆VOUT divided by maximum ∆T of the temperature range.
_______________________________________________________________________________________ 3
