Datasheet MAX873, MAX875, MAX876 (Analog Devices) - 5
Описание | Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage Reference |
Страниц / Страница | 12 / 5 — Low-Power, Low-Drift, +2.5V/+5V/+10V. Precision Voltage References. … |
Формат / Размер файла | PDF / 388 Кб |
Язык документа | английский |
Low-Power, Low-Drift, +2.5V/+5V/+10V. Precision Voltage References. MAX873/MAX875/MAX876
Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References MAX873/MAX875/MAX876 Typical Operating Characteristics (continued)
(VIN = +5V for VOUT = +2.5V, VIN = +15V for VOUT = +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
MINIMUM INPUT-OUTPUT DIFFERENTIAL POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO vs. SOURCE CURRENT (VOUT = 10V) vs. FREQUENCY (VOUT = 2.5V) vs. FREQUENCY (VOUT = 10V)
2.5 0 0 -20 -20 2.0 MAX873/75/76 toc10 MAX873/75/76 toc11 MAX873/75/76 toc12 T -40 A = +125°C -40 -60 1.5 -60 TA = +25°C PSRR (dB) -80 PSRR (dB) -80 DROPOUT VOLTAGE (V) -100 1.0 TA = -40°C -100 -120 0.5 -140 -120 0 4 8 12 16 20 0.001 0.01 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1000 SOURCE CURRENT (mA) FREQUENCY (kHz) FREQUENCY (kHz)
OUTPUT IMPEDANCE vs. FREQUENCY SUPPLY CURRENT vs. INPUT VOLTAGE SUPPLY CURRENT vs. INPUT VOLTAGE (VOUT = 2.5V) (VOUT = 2.5V) (VOUT = 10V)
400 400 100 TA = +125°C TA = +125°C 350 350 10 ) 300 300 MAX873/75/76 toc13 Ω MAX873/75/76 toc14 A) MAX873/75/76 toc15 µ µA) 250 TA = +25°C 250 1 TA = +25°C TA = -40°C 200 200 0.1 150 150 TA = -40°C SUPPLY CURRENT ( SUPPLY CURRENT ( OUTPUT IMPEDANCE ( 100 100 0.01 50 50 0.001 0 0 0.01 0.1 1 10 100 1000 0 5 10 15 20 25 30 35 40 0 5 10 15 20 25 30 35 40 FREQUENCY (kHz) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE TEMP VOLTAGE (VOUT = 2.5V) (VOUT = 10V) vs. TEMPERATURE (VOUT = 2.5V)
350 375 800 350 325 MAX873/75/76 toc16 A) 700 MAX873/75/76 toc17 A) MAX873/75/76 toc18 µ µ 325 300 600 300 SUPPLY CURRENT ( SUPPLY CURRENT ( TEMP VOLTAGE (mV) 275 500 275 250 250 400 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
_______________________________________________________________________________________ 5
