Datasheet MAX44260 (Analog Devices) - 4
Описание1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps
Страниц / Страница14 / 4 — Electrical Characteristics (continued). Note 2:. Note 3:. Note 4:. …
Electrical Characteristics (continued). Note 2:. Note 3:. Note 4:. Typical Operating Characteristics
Electrical Characteristics (continued) Note 2: Note 3: Note 4: Typical Operating Characteristics
37 предложений от 17 поставщиков
Микросхема Операционный усилитель, MAXIM INTEGRATED PRODUCTS MAX44260AYT+T Operational Amplifier, Rail to Rail I/O, 1 Amplifier, 15MHz, 7V/µs, 1.8V to 5.5V, µDFN,...
MAX44260AYT+T
Maxim
105 ₽
MAX44260AYT+T
Maxim
115 ₽
Эиком
MAX44260AYT+T
от 253 ₽
MAX44260AYT+T
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Shutdown Input Low VIL (Note 4) 0.5 V Shutdown Input High VIH (Note 4) 1.3 V Output Leakage Current in I Shutdown SHDN (Note 4) 100 pA MAX44260 1 Shutdown Input Bias Current IIL/IIH µA MAX44261 0.1 Shutdown Turn-On Time TA = +25NC (Note 3) 14.4 18.9 t µs (Note 4) SHDN TA = -40°C to +125°C (Note 3) 26.7 TA = +25NC (Note 3) 9.7 15.2 Turn-On Time tON ms TA = -40°C to +125°C (Note 3) 18.4 CAL Turn-On Time T (MAX44261 Only) CAL TA = +25°C (Note 3) 10 ms
Note 2:
All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.
Note 3:
Guaranteed by design.
Note 4:
MAX44259/MAX44260 only.
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted. All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.) INPUT OFFSET VOLTAGE INPUT OFFSET VOLTAGE vs. COMMON-MODE VOLTAGE vs. SUPPLY VOLTAGE INPUT VOS HISTOGRAM 60 100 25 80 40 TA = -40°C MAX44260 toc01 60 MAX44260 toc02 20 MAX44260 toc03 20 40 20 T 15 A = +25°C 0 TA = -40°C 0 -20 10 -20 -40 INPUT OFFSET VOLTAGE (µV) TA = +25°C INPUT OFFSET VOLTAGE (µV) PERCENT OCCURRENCE (%) T -40 -60 A = +125°C 5 T -80 A = +125°C -60 -100 0 -0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -15 -10 -5 0 5 10 15 20 25 COMMON-MODE VOLTAGE (V) SUPPLY VOLTAGE (V) INPUT OFFSET VOLTAGE (µV) www.maximintegrated.com Maxim Integrated │ 4
