Datasheet MAX32625 (Analog Devices) - 9
ОписаниеUltra-Low-Power Arm Cortex-M4 with FPU-Based Microcontroller (MCU) with 512KB Flash and 160KB SRAM
Страниц / Страница28 / 9 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
Формат / Размер файлаPDF / 806 Кб
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. JTAG. CLOCKS. FLASH MEMORY
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS JTAG CLOCKS FLASH MEMORY
7 предложений от 7 поставщиков
, IC MCU 32BIT 256KB FLASH 68TQFN
MAX32626ITKBL+T
Maxim
252 ₽
MAX32626ITKBL+T
Maxim
269 ₽
MAX32626ITKBL+T
Maxim
684 ₽
Hi-Tech Circuit Group
MAX32626ITKBL+T
MAX32625/MAX32626 Ultra-Low-Power Arm Cortex-M4 with FPU-Based Microcontroller (MCU) with 512KB Flash and 160KB SRAM
(Limits are 100% tested at TA = +25ºC and TA = +85ºC. Limits over the operating temperature range and relevant supply voltage range are guaranteed by design and characterization. Specifications marked GBD are guaranteed by design and not production tested. Specifications to -30°C are guaranteed by design and are not production tested.)
Input Pullup Resistor to SRSTN, TMS, TCK, TDI RPU_VDDIO Pullup to VDDIO 25 kΩ Input Pullup Resistor to RSTN RPU_VRTC Pullup to VRTC 25 kΩ Input Pullup/Pulldown Re- RPU_NORM Normal resistance, pin configured as GPIO 25 kΩ sistor for All GPIO RPU_HIGH Highest resistance, pin configured as GPIO 1 MΩ
JTAG
Input Low Voltage for TCK, 0.3 x TMS, TDI VIL V V DDIO Input High Voltage for TCK, 0.7 x TMS, TDI VIH V V DDIO Output Low Voltage for TDO VOL 0.2 0.4 V Output High Voltage for VDDIO - TDO VOH 0.4 V
CLOCKS
System Clock Frequency fSYS_CLK 0.001 98 MHz System Clock Period t 1/fSYS_ SYS_CLK ns CLK Factory default 94 96 98 Internal Relaxation Oscilla- tor Frequency fINTCLK Firmware trimmed, required for USB com- MHz pliance 95.76 96 96.24 Internal RC Oscillator Fre- quency fRCCLK 3.9 4 4.1 MHz RTC Input Frequency f32KIN 32kHz watch crystal, 6pF, ESR < 70kΩ 32.768 kHz I RTC Operating Current RTC_LP23 LP2 or LP3 mode 0.7 μA IRTC_LP01 LP0 or LP1 mode 0.35 RTC Power-Up Time tRTC_ ON 250 ms
FLASH MEMORY
Page Size 8 KB tM_ERASE Mass erase 30 Flash Erase Time ms tP_ERASE Page erase 30 Flash Programming Time Per Word tPROG 60 μs Flash Endurance 10 kcycles Data Retention tRET TA = +25°C 10 years www.maximintegrated.com Maxim Integrated │ 9 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 63 WLP 68 TQFN Electrical Characteristics Electrical Characteristics - ADC Electrical Characteristics - USB Electrical Characteristics - SPI Master / SPIX Master Electrical Characteristics - SPI Slave Electrical Characteristics - I2C Bus Pin Configurations Pin Description Detailed Description MAX32625/MAX32626 ARM Cortex-M4 with FPU Processor Power Operating Modes Low Power Mode 0 (LP0) Low Power Mode 1 (LP1) Low Power Mode 2 (LP2) Low Power Mode 3 (LP3) Analog-to-Digital Converter Pulse Train Engine Clocking Scheme Interrupt Sources Real-Time Clock and Wake-Up Timer General-Purpose I/O and Special Function Pins CRC Module Watchdog Timers Programmable Timers Serial Peripherals USB I2C Master and Slave SPI (Master) SPI (Slave) SPI (Execute in Place (SPIX) Master) UART 1-Wire Master Peripheral Management Unit (PMU) Additional Documentation Development and Technical Support Trust Protection Unit (TPU) (MAX32626 Only) Applications Information General-Purpose I/O Matrix Typical Application Circuit Ordering Information Revision History
