Datasheet TB9M001FTG (Toshiba) - 4
ПроизводительToshiba
ОписаниеAutomotive IC for DC motors with integrated microcontroller
Страниц / Страница38 / 4 — Preliminary. 6. Pin Assignments. Figure 6.1 Pin Assignment Diagram
Формат / Размер файлаPDF / 4.9 Мб
Preliminary 6 Pin Assignments Figure 6.1 Pin Assignment Diagram
Preliminary
TB9M001FTG
6. Pin Assignments
(Top view) O I D N I SD S 1/S 0/ C SD xd xd IN IN X/ L-TX/ T_T T_R L-R D R R N xd/IG A A S /F FD /U /U T_Txd/IG T_R LK IO/ C _x _x _x/C D _x M M M AR AR W W M U W W W W P P 11/U 13/S 12/S _10/ _3/ _2/ 1/P 0/P 1 T 0 IO_ IO IO_ IO_ IO IO IO_ IO_ D D OU IN P P P M M X X GP G GP GP G G GP GP 36 35 34 33 32 31 30 29 28 27 26 25 VDD 37 24 GPIO_8/SCLK/UART_Rxd GND 38 23 GPIO_9/SDI/UART_Txd RSTn 39 22 GPIO_7/SDO/ADIN7/UART_Txd/PWM_x ADIN1 40 21 GPIO_6/CSN/ADIN6/UART_Rxd/PWM_x ADIN2 41 20 GPIO_5/ADIN5 OUTH1(VCC) 42 GPIO_4/ADIN4 VCC 43 VQFN48 19 18 ADIN3/TSEN VAREF 44 17 TEST GNDA 45 16 HVIB3/HPIN3 ADIN0 46 15 HVIB2/HPIN2 VB 47 14 HVIB1/HPIN1 OUTH0(VB) 48 13 HVIB0/HPIN0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 D 2 3 4 IN IN LIN IN IN IN TL0 TL1 TL2 TL3 GN NDP /SW /SW /SW /SW /SW G OU OU OU OU LIN A0 A1 A2 A3 A4 VI VI VI VI VI H H H H H
© 2 025 4 2025-05-30 Toshiba Electronic Devices & Storage Corporation Rev. 1.0 Document Outline 1. Description 2. Applications 3. Features 4. Functions 5. Block Diagram 6. Pin Assignments 7. Pin Description 8. I/O Equivalent Circuits 9. Functional Description 9.1. CPU 9.1.1. Overview 9.1.2. Arm® Cortex®-M0 Processor 9.1.3. Configurable Options 9.1.4. External Signals 9.1.5. Module Organization 9.2. LINPHY 9.3. LINCNT/UART1 9.4. SPI 9.4.1. External Signals 9.5. GPIO 9.6. 10bit Analog Digital Converter (GADC) 9.7. Low Side Drivers (LSD) 9.8. High Side Drivers (HSD) 9.9. High Voltage Inputs (HVIF) 9.10. Memory Map 10. Electrical Characteristics 10.1. Absolute Maximum Ratings 10.2. Operating Ranges 10.3. Overall Electrical Characteristics 10.4. 5-V/1.5-V Regulator (LDO5V/LDO15V) 10.5. Switch and Hall Sensor IC Inputs(High Voltage Inputs) 10.6. Oscillator 10.7. Reset Generator and Standby Time 10.8. Data Flash 10.9. Program Flash 10.10. LIN 10.11. 12-V High-Side Driver (HSD_VB) 10.12. 5-V High-Side Driver (HSD_VCC) 10.13. Low-Side Drivers 10.14. 10-Bit AD 10.15. DC characteristics 10.16. SPI 10.17. UART 11. Application Circuit Example 12. Package Information 12.1. Package Dimensions 12.2. Marking 13. IC Usage Considerations 13.1. Notes on Handling of ICs 13.2. Points to Remember on Handling of ICs RESTRICTIONS ON PRODUCT USE
