Datasheet LT3041 (Analog Devices) - 10
Описание20 V, 1 A, Ultra-Low Noise, Ultra-High PSRR Linear Regulator with VIOC Control
Страниц / Страница36 / 10 — LT3041. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 13. ΔI. Figure 10. …
Формат / Размер файлаPDF / 2.5 Мб
LT3041. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 13. ΔI. Figure 10. SET Pin Current vs. Output Voltage
LT3041 TYPICAL PERFORMANCE CHARACTERISTICS Figure 13 ΔI Figure 10 SET Pin Current vs Output Voltage
IC REG LINEAR POS ADJ 1A 14DFN
LT3041ADE#TRPBF
438 ₽
LT3041ADE#TRPBF
703 ₽
Microfind
LT3041ADE#TRPBF
812 ₽
Data Sheet
LT3041 TYPICAL PERFORMANCE CHARACTERISTICS Figure 13. ΔI Figure 10. SET Pin Current vs. Output Voltage SET and ΔVOS Load Regulation vs. Temperature Figure 14. Quiescent Current vs. Temperature (V Figure 11. Offset Voltage (V EN/UV = VIN) OUT – VSET) vs. Output Voltage Figure 15. Quiescent Current vs. Temperature (V Figure 12. Error Amplifier Switchover Point vs. Temperature EN/UV = 0 V) analog.com Rev. 0 | 10 of 36
Document Outline Features Applications Typical Application General Description Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Output Voltage Output Sensing and Stability Stability and Output Capacitance High Vibration Environments Stability and Input Capacitance PSRR and Input Capacitance Filtering High-Frequency Spikes Output Noise SET Pin (Bypass) Capacitance: Noise, PSRR, Transient Response, and Soft-Start Fast Startup EN/UV Programmable Power Good Externally Programmable Current Limit Output Overshoot Recovery Direct Paralleling for Higher Current PCB Layout Considerations High-Efficiency Linear Regulator: Voltage Input-to-Output Control (VIOC) Typical VIOC Application Thermal Considerations Calculating Junction Temperature Overload Recovery Protection Features Typical Applications Related Products Outline Dimensions Ordering Guide Evaluation Boards
