Datasheet LTC2972 (Analog Devices) - 2
Описание2-Channel PMBus Power System Manager Featuring Programmable Power Good Outputs
Страниц / Страница112 / 2 — TABLE OF CONTENTS Features ..1. Applications ...1. Typical Application …
Формат / Размер файлаPDF / 3.0 Мб
TABLE OF CONTENTS Features ..1. Applications ...1. Typical Application ...1. Description...1. Absolute Maximum Ratings ...4
TABLE OF CONTENTS Features ..1 Applications ...1 Typical Application ...1 Description...1 Absolute Maximum Ratings ...4
29 предложений от 12 поставщиков
2-CHANNEL PMBUS POWER SYSTEM MAN. Power Supply Controller Monitor, Sequencer, Supervisor 44-QFN (6x7). PMIC - Power Supply Controllers, Monitors
Рутоника
LTC2972IUJF#TRPBF
465 ₽
LTC2972IUJF#PBF
1 025 ₽
Элитан
LTC2972IUJF
1 502 ₽
Hi-Tech Circuit Group
LTC2972IUJF#TRPBF
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 4 link to page 4 link to page 5 link to page 11 link to page 12 link to page 16 link to page 18 link to page 19 link to page 19 link to page 20 link to page 20 link to page 20 link to page 20 link to page 21 link to page 21 link to page 21 link to page 21 link to page 31 link to page 31 link to page 32 link to page 32 link to page 33 link to page 33 link to page 33 link to page 33 link to page 33 link to page 34 link to page 35 link to page 35 link to page 35 link to page 35 link to page 36 link to page 36 link to page 36 link to page 37 link to page 38 link to page 38 link to page 40 link to page 41 link to page 41 link to page 42 link to page 42 link to page 44 link to page 46 link to page 46 link to page 47 link to page 47 link to page 47 link to page 48 link to page 48 link to page 48 link to page 49 link to page 49 link to page 49 link to page 49 link to page 49 link to page 49 link to page 50 link to page 51 link to page 51 link to page 51 link to page 52 link to page 52 link to page 53 link to page 53 link to page 53 link to page 53 link to page 53 link to page 53 link to page 53 link to page 53 link to page 54 link to page 54 link to page 54 link to page 54 link to page 55 link to page 56 link to page 56 link to page 56 link to page 56 link to page 56 link to page 58 link to page 58 link to page 58 link to page 59 link to page 59 link to page 59 link to page 60 link to page 62 link to page 62 link to page 62 link to page 63 link to page 63 link to page 63 link to page 64 link to page 64 link to page 64 link to page 65 link to page 65 link to page 65 link to page 66 link to page 66 link to page 67 link to page 67 link to page 67 link to page 68 link to page 68 LTC2972
VIN_ON, VIN_OFF, VIN_OV_FAULT_LIMIT, VIN_OV_WARN_
Applications ...1
LIMIT, VIN_UV_WARN_LIMIT and
VIN_UV_FAULT_LIMIT ... 49
Description...1
INPUT Current and ENERGY .. 49
Energy Measurement and Reporting ... 49
Order Information ...4
MFR_EIN ... 49
Pin Configuration ...4
MFR_EIN_CONFIG ... 50
Electrical Characteristics ..5
MFR_IIN_CAL_GAIN ..51
PMBus Timing Diagram .. 11
MFR_IIN_CAL_GAIN_TC ..51
Typical Performance Characteristics .. 12
MFR_CLEAR_ENERGY ...51
Pin Functions .. 16
Output Voltage Commands and Limits.. 52
Block Diagram ... 18
VOUT_MODE .. 52
Operation... 19
VOUT_COMMAND, VOUT_MAX, VOUT_MARGIN_HIGH, VOUT_ LTC2972 Operation Overview ...19 MARGIN_LOW, VOUT_OV_FAULT_LIMIT, EEPROM ... 20 VOUT_OV_WARN_LIMIT, VOUT_UV_WARN_LIMIT, VOUT_UV_ AUXFAULTB ... 20 FAULT_LIMIT, POWER_GOOD_ON and RESETB .. 20 POWER_GOOD_OFF .. 53 VDDIO ...20 MFR_VOUT_DISCHARGE_THRESHOLD .. 53 PMBus Serial Digital Interface .. 21 MFR_DAC_STARTUP ... 53 PMBus .. 21 MFR_DAC ... 53 Device Address .. 21 Output CURRENT Commands and Limits ... 54 Processing Commands .. 21 IOUT_CAL_GAIN and IOUT_CAL_OFFSET .. 54 Addressing and Write Protect ... 31 IOUT_OC_WARN_LIMIT .. 54 PAGE .. 31 MFR_IOUT_CAL_GAIN_TC .. 54 WRITE_PROTECT .. 32 External Temperature Commands and Limits ... 55 WRITE PROTECT Pin ... 32 OT_FAULT_LIMIT, OT_WARN_LIMIT, UT_WARN_LIMIT and MFR_PAGE_FF_MASK ... 33 UT_FAULT_LIMIT ... 56 MFR_I2C_BASE_ADDRESS .. 33 MFR_TEMP_1_GAIN and MFR_TEMP_1_OFFSET ... 56 MFR_COMMAND_PLUS .. 33 MFR_T_SELF_HEAT, MFR_IOUT_CAL_GAIN_TAU_INV and MFR_ MFR_DATA_PLUS0 and MFR_DATA_PLUS1 .. 33 IOUT_CAL_GAIN_THETA ... 56 MFR_STATUS_PLUS0, and MFR_STATUS_PLUS1 .. 33 Sequencing Timing Limits and Clock Sharing... 58 Reading Fault Log Using Command Plus and MFR_DATA_PLUS0 . 34 TON_DELAY, TON_RISE, TON_MAX_FAULT_LIMIT and TOFF_ Reading Energy Using MFR_COMMAND_PLUS and MFR_DATA_ DELAY .. 58 PLUS0 .. 35 MFR_RESTART_DELAY ... 59 Peek Operation Using MFR_DATA_PLUS0 .. 35 Clock Sharing ... 59 Enabling and Disabling Poke Operations ... 35 Watchdog Timer and Power Good ... 59 Poke Operation Using Mfr_data_plus0 ... 36 MFR_PG_CONFIG .. 60 Command Plus Operations Using MFR_DATA_PLUS1 ... 36 MFR_PG_GPO ... 62 On/Off Control, Margining and Configuration ... 36 MFR_PWRGD_EN .. 62 OPERATION .. 37 MFR_POWERGOOD_ASSERTION_DELAY .. 62 ON_OFF_CONFIG ... 38 Watchdog Operation .. 63 MFR_CONFIG_LTC2972 .. 38 MFR_WATCHDOG_T_FIRST and MFR_WATCHDOG_T ... 63 Cascade Sequence ON with Time-Based Sequence OFF ... 40 Fault Responses .. 63 MFR_CONFIG2_LTC2972 ...41 Clearing Latched Faults ... 64 MFR_CONFIG3_LTC2972 ...41 VOUT_OV_FAULT_RESPONSE and VOUT_UV_FAULT_RESPONSE Tracking Supplies On and Off .. 42 64 Tracking Implementation ... 42 OT_FAULT_RESPONSE, UT_FAULT_RESPONSE, VIN_OV_FAULT_ MFR_CONFIG_ALL_LTC2972 ... 44 RESPONSE and VIN_UV_FAULT_RESPONSE.. 65 Programming User EEPROM Space .. 46 TON_MAX_FAULT_RESPONSE ... 65 STORE_USER_ALL and RESTORE_USER_ALL .. 46 MFR_RETRY_DELAY ... 66 MFR_EE_UNLOCK ... 47 MR_RETRY_COUNT .. 66 MFR_EE_ERASE .. 47 Shared External Faults ... 67 MFR_EE_DATA ... 47 MFR_FAULTB0_PROPAGATE and MFR_FAULTB1_PROPAGATE 67 Response When Part Is Busy... 48 MFR_FAULTB0_RESPONSE and MFR_FAULTB1_RESPONSE ... 67 MFR_EE Erase and Write Programming Time ... 48 Fault Warning and Status .. 68 Input Voltage Commands and Limits .. 48 CLEAR_FAULTS ... 68 Rev. C 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics PMBus Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Operation LTC2972 Operation Overview EEPROM AUXFAULTB RESETB VDDIO PMBus Serial Digital Interface PMBus Device Address Processing Commands Addressing and Write Protect PAGE WRITE_PROTECT WRITE PROTECT Pin MFR_PAGE_FF_MASK MFR_I2C_BASE_ADDRESS MFR_COMMAND_PLUS MFR_DATA_PLUS0 and MFR_DATA_PLUS1 MFR_STATUS_PLUS0, and MFR_STATUS_PLUS1 Reading Fault Log Using Command Plus and MFR_DATA_PLUS0 Reading Energy Using MFR_COMMAND_PLUS and MFR_DATA_PLUS0 Peek Operation Using MFR_DATA_PLUS0 Enabling and Disabling Poke Operations Poke Operation Using Mfr_data_plus0 Command Plus Operations Using MFR_DATA_PLUS1 On/Off Control, Margining and Configuration OPERATION ON_OFF_CONFIG MFR_CONFIG_LTC2972 Cascade Sequence ON with Time-Based Sequence OFF MFR_CONFIG2_LTC2972 MFR_CONFIG3_LTC2972 Tracking Supplies On and Off Tracking Implementation MFR_CONFIG_ALL_LTC2972 Programming User EEPROM Space STORE_USER_ALL and RESTORE_USER_ALL MFR_EE_UNLOCK MFR_EE_ERASE MFR_EE_DATA Response When Part Is Busy MFR_EE Erase and Write Programming Time Input Voltage Commands and Limits VIN_ON, VIN_OFF, VIN_OV_FAULT_LIMIT, VIN_OV_WARN_LIMIT, VIN_UV_WARN_LIMIT and VIN_UV_FAULT_LIMIT INPUT Current and ENERGY Energy Measurement and Reporting MFR_EIN MFR_EIN_CONFIG MFR_IIN_CAL_GAIN MFR_IIN_CAL_GAIN_TC MFR_CLEAR_ENERGY Output Voltage Commands and Limits VOUT_MODE VOUT_COMMAND, VOUT_MAX, VOUT_MARGIN_HIGH, VOUT_MARGIN_LOW, VOUT_OV_FAULT_LIMIT, VOUT_OV_WARN_LIMIT, VOUT_UV_WARN_LIMIT, VOUT_UV_FAULT_LIMIT, POWER_GOOD_ON and POWER_GOOD_OFF MFR_VOUT_DISCHARGE_THRESHOLD MFR_DAC_STARTUP MFR_DAC Output CURRENT Commands and Limits IOUT_CAL_GAIN and IOUT_CAL_OFFSET IOUT_OC_WARN_LIMIT MFR_IOUT_CAL_GAIN_TC External Temperature Commands and Limits OT_FAULT_LIMIT, OT_WARN_LIMIT, UT_WARN_LIMIT and UT_FAULT_LIMIT MFR_TEMP_1_GAIN and MFR_TEMP_1_OFFSET MFR_T_SELF_HEAT, MFR_IOUT_CAL_GAIN_TAU_INV and MFR_IOUT_CAL_GAIN_THETA Sequencing Timing Limits and Clock Sharing TON_DELAY, TON_RISE, TON_MAX_FAULT_LIMIT and TOFF_DELAY MFR_RESTART_DELAY Clock Sharing Watchdog Timer and Power Good MFR_PG_CONFIG MFR_PG_GPO MFR_PWRGD_EN MFR_POWERGOOD_ASSERTION_DELAY Watchdog Operation MFR_WATCHDOG_T_FIRST and MFR_WATCHDOG_T Fault Responses Clearing Latched Faults VOUT_OV_FAULT_RESPONSE and VOUT_UV_FAULT_RESPONSE OT_FAULT_RESPONSE, UT_FAULT_RESPONSE, VIN_OV_FAULT_RESPONSE and VIN_UV_FAULT_RESPONSE TON_MAX_FAULT_RESPONSE MFR_RETRY_DELAY MR_RETRY_COUNT Shared External Faults MFR_FAULTB0_PROPAGATE and MFR_FAULTB1_PROPAGATE MFR_FAULTB0_RESPONSE and MFR_FAULTB1_RESPONSE Fault Warning and Status CLEAR_FAULTS STATUS_BYTE STATUS_WORD STATUS_VOUT STATUS_IOUT STATUS_INPUT STATUS_TEMPERATURE STATUS_CML STATUS_MFR_SPECIFIC MFR_PADS MFR_COMMON MFR_STATUS_2 MFR_FIRST_FAULT Telemetry READ_VIN READ_IIN READ_PIN READ_VOUT READ_IOUT MFR_IIN_PEAK READ_TEMPERATURE_2 READ_POUT MFR_READ_IOUT MFR_IOUT_SENSE_VOLTAGE MFR_VIN_PEAK MFR_TEMPERATURE_1_MIN Fault Logging Fault Log Operation MFR_FAULT_LOG_STORE MFR_FAULT_LOG_RESTORE MFR_FAULT_LOG_CLEAR MFR_FAULT_LOG_STATUS MFR_FAULT_LOG MFR_FAULT_LOG Read Example Identification/Information CAPABILITY PMBUS_REVISION MFR_SPECIAL_ID MFR_SPECIAL_LOT MFR_INFO User Scratchpad USER_DATA_00, USER_DATA_01, USER_DATA_02, USER_DATA_03, USER_DATA_04 and MFR_LTC_RESERVED_2 Applications Information Overview Powering the LTC2972 Setting Command Register Values MEASURING INPUT CURRENT MEASURING INPUT VOLTAGE MEASURING INPUT POWER Measuring INPUT ENERGY Sequence, Servo, Margin and Restart Operations Command Units On or Off On Sequencing On State Operation Servo Modes DAC Modes Margining Off Sequencing VOUT Off Threshold Voltage Automatic Restart via MFR_RESTART_DELAY Command and CONTROL Pin Fault Management Output Overvoltage and Undervoltage Faults Output Overvoltage, Undervoltage, and Overcurrent Warnings Configuring the AUXFAULTB Output Multi-Channel Fault Management Interconnect Between Multiple ADI POWER MANAGERS Application Circuits Trimming and Margining DC/DC Converters with External Feedback Resistors Four-Step Resistor Selection Procedure for DC/DC Converters with External Feedback Resistors Trimming and Margining DC/DC Converters with a TRIM Pin Two-Step Resistor and DAC Full-Scale Voltage Selection Procedure for DC/DC Converters with a TRIM Pin Measuring Output with a Sense Resistor Measuring Output with Inductor DCR Single Phase Design Example Measuring Multiphase Currents Measuring Output Current in Buffered IMON Telemetry Mode LT3086 IMON Design Example Anti-Aliasing Filter Considerations Sensing Negative Voltages Connecting the DC1613 USB to I2C/SMBus/PMBus Controller to the LTC2972 in System Accurate DCR Temperature Compensation LTpowerPlay: An Interactive GUI for Power Managers PCB Assembly and Layout Suggestions Bypass Capacitor Placement Exposed Pad Stencil Design PCB Board Layout Unused ADC Sense Inputs Design Checklist I2C Output Enables VIN Sense Input Current Sense External Temperature Sense Logic Signals Unused Inputs DAC Outputs Package Description Revision History Typical Application Related Parts
