Datasheet LTC2972 (Analog Devices) - 6
Описание2-Channel PMBus Power System Manager Featuring Programmable Power Good Outputs
Страниц / Страница112 / 6 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
Формат / Размер файлаPDF / 3.0 Мб
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
2-CHANNEL PMBUS POWER SYSTEM MAN. Power Supply Controller Monitor, Sequencer, Supervisor 44-QFN (6x7). PMIC - Power Supply Controllers, Monitors
LTC2972IUJF#TRPBF
230 ₽
Рутоника
LTC2972IUJF#TRPBF
465 ₽
LTC2972IUJF#TRPBF
537 ₽
LTC2972IUJF#TRPBF
LTC2972
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TJ = 25°C. VPWR = VIN_SNS = 12V, VDD33 = VDDIO, VDD33, VDD25, REFP and REFM pins floating, unless otherwise indicated. CVDD33 = 100nF, CVDD25 = 100nF, CVIN_SNS_CAP = 10nF and CREF = 100nF. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
TUE_ADC_ Total Unadjusted Error (Note 3) Current Sense Inputs 20mV ≤ |VIN_ADC| ≤ 170mV l ±0.3 % of Reading CURR_SNS Mfr_config_imon_sel = 0 Current Sense Inputs |VIN_ADC| ≤ 20mV l ±60 µV Mfr_config_imon_sel = 0 Current Sense Inputs VIN_ADC ≥ 1V l ±0.25 % of Reading Mfr_config_imon_sel = 1 Current Sense Inputs 0 ≤ VIN_ADC ≤ 1V l ±2.5 mV Mfr_config_imon_sel = 1 VOS_ADC Offset Error ISENSEPn and ISENSEMn Inputs, VOS • IOUT_CAL_ l ±35 µV GAIN, IOUT_CAL_GAIN = 1000mΩ Mfr_config_imon_sel = 0 tCONV_ADC Conversion Time VSENSEPn, VSENSEMn, VIN_SNS Inputs (Note 6) 6.15 ms ISENSEPn and ISENSEMn Inputs (Note 6) 24.6 ms Mfr_config_imon_sel = 0 ISENSEPn and ISENSEMn Inputs (Note 6) 6.15 ms Mfr_config_imon_sel = 1 Internal Temperature 24.6 ms (READ_TEMPERATURE_2) (Note 6) tUPDATE_ADC Update Time Mfr_ein_config_hd = 0 (Note 6) 135 ms Mfr_ein_config_hd = 1 (Note 6) 305 ms fIN_ADC Input Sampling Frequency 62.5 kHz
Sense Input Current Characteristics (Note 7)
IIN_VSENSE Input Current VSENSEPn and VSENSEMn Inputs l ±15 µA Differential Input Current VSENSEPn and VSENSEMn Inputs, VIN_DIFF = 6V l ±30 µA IIN_ISENSE Input Current ISENSEPn and ISENSEMn Inputs l ±1 µA Mfr_config_imon_sel = 0 ISENSEPn and ISENSEMn Inputs l ±6 µA Mfr_config_imon_sel = 1 Differential Input Current ISENSEPn and ISENSEMn Inputs, |VIN_DIFF| = 170mV l ±1 µA Mfr_config_imon_sel = 0 ISENSEPn and ISENSEMn Inputs, |VIN_DIFF| = 6.0V l ±12 µA Mfr_config_imon_sel = 1
DAC Output Characteristics
N_VDAC Resolution 10 Bits VFS_VDAC Full-Scale Output Voltage DAC Code = 0x3FF Buffer Gain Setting_0 l 1.3 1.38 1.44 V (Programmable) DAC Polarity = 1 Buffer Gain Setting_1 l 2.5 2.65 2.77 V INL_VDAC Integral Nonlinearity (Note 8) l ±2 LSB DNL_VDAC Differential Nonlinearity (Note 8) l ±2.4 LSB VOS_VDAC Offset Voltage (Note 8) l ±10 mV VDAC Load Regulation VDACn = 2.65V, IVDACn Sourcing = 2mA 100 ppm/mA VDACn = 0.1V, IVDACn Sinking = 2mA 100 ppm/mA PSRR DC: 3.13V ≤ VDD33 ≤ 3.47V, VPWR = VDD33 60 dB Leakage Current VDACn Hi-Z, 0V ≤ VDACn ≤ 6V l ±100 nA Short-Circuit Current Low VDACn Shorted to GND l –12 –4 mA Short-Circuit Current High VDACn Shorted to VDD33 l 4 12 mA Rev. C 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics PMBus Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Operation LTC2972 Operation Overview EEPROM AUXFAULTB RESETB VDDIO PMBus Serial Digital Interface PMBus Device Address Processing Commands Addressing and Write Protect PAGE WRITE_PROTECT WRITE PROTECT Pin MFR_PAGE_FF_MASK MFR_I2C_BASE_ADDRESS MFR_COMMAND_PLUS MFR_DATA_PLUS0 and MFR_DATA_PLUS1 MFR_STATUS_PLUS0, and MFR_STATUS_PLUS1 Reading Fault Log Using Command Plus and MFR_DATA_PLUS0 Reading Energy Using MFR_COMMAND_PLUS and MFR_DATA_PLUS0 Peek Operation Using MFR_DATA_PLUS0 Enabling and Disabling Poke Operations Poke Operation Using Mfr_data_plus0 Command Plus Operations Using MFR_DATA_PLUS1 On/Off Control, Margining and Configuration OPERATION ON_OFF_CONFIG MFR_CONFIG_LTC2972 Cascade Sequence ON with Time-Based Sequence OFF MFR_CONFIG2_LTC2972 MFR_CONFIG3_LTC2972 Tracking Supplies On and Off Tracking Implementation MFR_CONFIG_ALL_LTC2972 Programming User EEPROM Space STORE_USER_ALL and RESTORE_USER_ALL MFR_EE_UNLOCK MFR_EE_ERASE MFR_EE_DATA Response When Part Is Busy MFR_EE Erase and Write Programming Time Input Voltage Commands and Limits VIN_ON, VIN_OFF, VIN_OV_FAULT_LIMIT, VIN_OV_WARN_LIMIT, VIN_UV_WARN_LIMIT and VIN_UV_FAULT_LIMIT INPUT Current and ENERGY Energy Measurement and Reporting MFR_EIN MFR_EIN_CONFIG MFR_IIN_CAL_GAIN MFR_IIN_CAL_GAIN_TC MFR_CLEAR_ENERGY Output Voltage Commands and Limits VOUT_MODE VOUT_COMMAND, VOUT_MAX, VOUT_MARGIN_HIGH, VOUT_MARGIN_LOW, VOUT_OV_FAULT_LIMIT, VOUT_OV_WARN_LIMIT, VOUT_UV_WARN_LIMIT, VOUT_UV_FAULT_LIMIT, POWER_GOOD_ON and POWER_GOOD_OFF MFR_VOUT_DISCHARGE_THRESHOLD MFR_DAC_STARTUP MFR_DAC Output CURRENT Commands and Limits IOUT_CAL_GAIN and IOUT_CAL_OFFSET IOUT_OC_WARN_LIMIT MFR_IOUT_CAL_GAIN_TC External Temperature Commands and Limits OT_FAULT_LIMIT, OT_WARN_LIMIT, UT_WARN_LIMIT and UT_FAULT_LIMIT MFR_TEMP_1_GAIN and MFR_TEMP_1_OFFSET MFR_T_SELF_HEAT, MFR_IOUT_CAL_GAIN_TAU_INV and MFR_IOUT_CAL_GAIN_THETA Sequencing Timing Limits and Clock Sharing TON_DELAY, TON_RISE, TON_MAX_FAULT_LIMIT and TOFF_DELAY MFR_RESTART_DELAY Clock Sharing Watchdog Timer and Power Good MFR_PG_CONFIG MFR_PG_GPO MFR_PWRGD_EN MFR_POWERGOOD_ASSERTION_DELAY Watchdog Operation MFR_WATCHDOG_T_FIRST and MFR_WATCHDOG_T Fault Responses Clearing Latched Faults VOUT_OV_FAULT_RESPONSE and VOUT_UV_FAULT_RESPONSE OT_FAULT_RESPONSE, UT_FAULT_RESPONSE, VIN_OV_FAULT_RESPONSE and VIN_UV_FAULT_RESPONSE TON_MAX_FAULT_RESPONSE MFR_RETRY_DELAY MR_RETRY_COUNT Shared External Faults MFR_FAULTB0_PROPAGATE and MFR_FAULTB1_PROPAGATE MFR_FAULTB0_RESPONSE and MFR_FAULTB1_RESPONSE Fault Warning and Status CLEAR_FAULTS STATUS_BYTE STATUS_WORD STATUS_VOUT STATUS_IOUT STATUS_INPUT STATUS_TEMPERATURE STATUS_CML STATUS_MFR_SPECIFIC MFR_PADS MFR_COMMON MFR_STATUS_2 MFR_FIRST_FAULT Telemetry READ_VIN READ_IIN READ_PIN READ_VOUT READ_IOUT MFR_IIN_PEAK READ_TEMPERATURE_2 READ_POUT MFR_READ_IOUT MFR_IOUT_SENSE_VOLTAGE MFR_VIN_PEAK MFR_TEMPERATURE_1_MIN Fault Logging Fault Log Operation MFR_FAULT_LOG_STORE MFR_FAULT_LOG_RESTORE MFR_FAULT_LOG_CLEAR MFR_FAULT_LOG_STATUS MFR_FAULT_LOG MFR_FAULT_LOG Read Example Identification/Information CAPABILITY PMBUS_REVISION MFR_SPECIAL_ID MFR_SPECIAL_LOT MFR_INFO User Scratchpad USER_DATA_00, USER_DATA_01, USER_DATA_02, USER_DATA_03, USER_DATA_04 and MFR_LTC_RESERVED_2 Applications Information Overview Powering the LTC2972 Setting Command Register Values MEASURING INPUT CURRENT MEASURING INPUT VOLTAGE MEASURING INPUT POWER Measuring INPUT ENERGY Sequence, Servo, Margin and Restart Operations Command Units On or Off On Sequencing On State Operation Servo Modes DAC Modes Margining Off Sequencing VOUT Off Threshold Voltage Automatic Restart via MFR_RESTART_DELAY Command and CONTROL Pin Fault Management Output Overvoltage and Undervoltage Faults Output Overvoltage, Undervoltage, and Overcurrent Warnings Configuring the AUXFAULTB Output Multi-Channel Fault Management Interconnect Between Multiple ADI POWER MANAGERS Application Circuits Trimming and Margining DC/DC Converters with External Feedback Resistors Four-Step Resistor Selection Procedure for DC/DC Converters with External Feedback Resistors Trimming and Margining DC/DC Converters with a TRIM Pin Two-Step Resistor and DAC Full-Scale Voltage Selection Procedure for DC/DC Converters with a TRIM Pin Measuring Output with a Sense Resistor Measuring Output with Inductor DCR Single Phase Design Example Measuring Multiphase Currents Measuring Output Current in Buffered IMON Telemetry Mode LT3086 IMON Design Example Anti-Aliasing Filter Considerations Sensing Negative Voltages Connecting the DC1613 USB to I2C/SMBus/PMBus Controller to the LTC2972 in System Accurate DCR Temperature Compensation LTpowerPlay: An Interactive GUI for Power Managers PCB Assembly and Layout Suggestions Bypass Capacitor Placement Exposed Pad Stencil Design PCB Board Layout Unused ADC Sense Inputs Design Checklist I2C Output Enables VIN Sense Input Current Sense External Temperature Sense Logic Signals Unused Inputs DAC Outputs Package Description Revision History Typical Application Related Parts
