Datasheet DMMT3904WQ (Diodes) - 3
ПроизводительDiodes
ОписаниеDual NPN, 40V, 0.2A, SOT363
Страниц / Страница6 / 3 — DMMT3904WQ. Electrical Characteristics. Characteristic. Symbol. Min. Typ. …
Формат / Размер файлаPDF / 466 Кб
DMMT3904WQ. Electrical Characteristics. Characteristic. Symbol. Min. Typ. Max. Unit. Test Condition. OFF CHARACTERISTICS
DMMT3904WQ Electrical Characteristics Characteristic Symbol Min Typ Max Unit Test Condition OFF CHARACTERISTICS
34 предложений от 12 поставщиков
TRANS 2NPN 40V 0.2A SOT363 / Bipolar (BJT) Transistor Array 2 NPN (Dual) 40V 200mA 300MHz 200mW Surface Mount SOT-363
DMMT3904WQ-7-F
Diodes
9.95 ₽
DMMT3904WQ-7-F
12 ₽
DMMT3904WQ-7-F
40 ₽
DMMT3904WQ-7-F
Diodes
(@TA = +25°C, unless otherwise specified.)
Collector-Base Breakdown Voltage BVCBO 60 — — V IC = 100µA, IE = 0 Collector-Emitter Breakdown Voltage (Note 8) BVCEO 40 — — V IC = 1.0mA, IB = 0 Emitter-Base Breakdown Voltage BVEBO 6.0 — — V IE = 100µA, IC = 0 Collector Cutoff Current ICEX — — 50 nA VCE = 30V, VEB(off) = 3.0V Base Cutoff Current IBL — — 50 nA VCE = 30V, VEB(off) = 3.0V
ON CHARACTERISTICS (Note 8)
40 — IC = 100µA, VCE = 1.0V 70 — IC = 1.0mA, VCE = 1.0V DC Current Gain hFE 100 — 300 — IC = 10mA, VCE = 1.0V 60 — IC = 50mA, VCE = 1.0V 30 — IC = 100mA, VCE = 1.0V — 200 IC = 10mA, IB = 1.0mA Collector-Emitter Saturation Voltage VCE(sat) — mV 300 IC = 50mA, IB = 5.0mA 650 850 IC = 10mA, IB = 1.0mA Base-Emitter Saturation Voltage VBE(sat) — — mV 950 IC = 50mA, IB = 5.0mA
MATCHING CHARACTERISTICS
DC Current Gain Matching (Note 9) hFE1 / hFE2 — 1 2 % IC = 2mA, VCE = 5V Base-Emitter Voltage Matching (Note 10) VBE1 - VBE2 — 1 2 mV IC = 2mA, VCE = 5V VCE(sat )1 Collector-Emitter Saturation Voltage (Note 9) / — 1 2 % IC = 10mA, IB = 1.0mA VCE(sat)2 VBE(sat)1 Base-Emitter Saturation Voltage (Note 9) / — 1 2 % IC = 10mA, IB = 1.0mA VBE(sat)2
SMALL SIGNAL CHARACTERISTICS
Output Capacitance COBO — — 4.0 pF VCB = 5.0V, f = 1.0MHz, IE = 0 Input Capacitance CIBO — — 8.0 pF VEB = 0.5V, f = 1.0MHz, IC = 0 Input Impedance hIE 1.0 — 10 kΩ Voltage Feedback Ratio hRE 0.5 — 8 x 10-4 VCE = 10V, IC = 1.0mA, Small Signal Current Gain f = 1.0kHz hFE 100 — 400 — Output Admittance hOE 1.0 — 40 µS V Current Gain-Bandwidth Product f CE = 20V, IC = 10mA, T 300 — — MHz f = 100MHz VCE = 5.0V, IC = 100µA, Noise Figure NF — — 5.0 dB RS = 1.0kΩ, f = 1.0kHz
SWITCHING CHARACTERISTICS
Delay Time tD — — 35 ns VCC = 3.0V, IC = 10mA, Rise Time t VBE(off) = -0.5V, IB1 = 1.0mA R — — 35 ns Storage Time tS — — 200 ns VCC = 3.0V, IC = 10mA, Fall Time t IB1 = -IB2 = 1.0mA F — — 50 ns Notes: 8. Measured under pulsed conditions. Pulse width ≤ 300µs. Duty cycle ≤ 2%. 9. Is the ratio of one transistor compared to the other transistor. 10. VBE1 - VBE2 is the absolute difference of one transistor compared to the other transistor. DMMT3904WQ 3 of 6 July 2020 Document number: DS42397 Rev. 1 - 2
www.diodes.com
© Diodes Incorporated
