Datasheet LF53466 (Littelfuse) - 2
Производитель | Littelfuse |
Описание | Omni-polar Magnetic Angle Sensor in TSSOP8 package |
Страниц / Страница | 5 / 2 — Datasheet. TSSOP8 LF53466-08TMR. Electrical Ratings (@TA = +25°C, Vcc = … |
Формат / Размер файла | PDF / 834 Кб |
Язык документа | английский |
Datasheet. TSSOP8 LF53466-08TMR. Electrical Ratings (@TA = +25°C, Vcc = 5V, B=200Gs). Symbol. Characteristics. Min. Typ. Max. Unit
Omnipolar TMR
Datasheet TSSOP8 LF53466-08TMR
Omnipolar Magnetic Sensor
Electrical Ratings (@TA = +25°C, Vcc = 5V, B=200Gs) Symbol Characteristics Min. Typ. Max. Unit
V Supply voltage 1.0 5.0 5.5 V CC V Output peak voltage - 300 - mV/V Peak CC V Output peak to peak voltage - 600 - mV/V PP CC V Offset Voltage -5 - 5 mV/V Offset CC R Bridge resistance 3 5 7 kΩ B V ESD performance (HBM) - - 4000 V ESD(HBM) V ESD performance (CDM) - - 750 V ESD(CDM) T Storage temperature -55 - 150 ˚C Storage T Working temperature -40 - 150 ˚C working
Magnetic Characteristics (@TA = +25°C, Vcc = 5V) Symbol Characteristics Min. Typ. Max. Unit
Bop Omnipolar Dynamic Range 200 - 800 G BMax Maximum magnetic field - - 4000 G θ Angle Range 0 - 360 ˚ Δθ Angular Error - 0.8 - ˚
Operation Principle
By rotating a small magnet placed on top of LF53466TMR, a rotating magnetic field paral el to the surface of the magnetic is generated and is at the same angle as the magnet. Bel ow figure shows the typical output signals of the LF53466TMR in response to a rotating field. © 2025 Littelfuse, Inc.
2
Specifications are subject to change without notice. VL 07/09/25
