Datasheet TCST1103 (Vishay) - 3
ПроизводительVishay
ОписаниеTransmissive Optical Sensor with Phototransistor Output
Страниц / Страница7 / 3 — TCST1103, TCST1202, TCST1300. BASIC CHARACTERISTICS. PARAMETER. TEST …
Формат / Размер файлаPDF / 109 Кб
TCST1103, TCST1202, TCST1300. BASIC CHARACTERISTICS. PARAMETER. TEST CONDITION. PART. SYMBOL. MIN. TYP. MAX. UNIT. INPUT (EMITTER)
TCST1103, TCST1202, TCST1300 BASIC CHARACTERISTICS PARAMETER TEST CONDITION PART SYMBOL MIN TYP MAX UNIT INPUT (EMITTER)
77 предложений от 30 поставщиков
Сенсоры, Датчики Оптические датчики — фотопрерыватели — щелевые — с транзисторным выходом
TCST1103
50 ₽
Microfind
TCST1103
от 78 ₽
TCST1103
от 121 ₽
LifeElectronics
TCST1103A
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT INPUT (EMITTER)
Forward voltage IF = 60 mA VF 1.25 1.6 V Junction capacitance VR = 0 V, f = 1 MHz Cj 50 pF
OUTPUT (DETECTOR)
Collector emitter voltage IC = 1 mA VCEO 70 V Emitter collector voltage IE = 10 μA VECO 7 V Collector dark current VCE = 25 V, IF = 0 A, E = 0 lx ICEO 100 nA
SWITCHING CHARACTERISTICS
I Turn-on time C = 2 mA, VS = 5 V, t R on 10 μs L = 100 Ω (see figure 2) I Turn-off time C = 2 mA, VS = 5 V, t R off 8 μs L = 100 Ω (see figure 2) I F 0 t p t IC I I + 5 V F F 0 100 % IC adjusted by IF 90 % R G = 50 Ω tp = 20 T t 10 % p = 1 ms 0 t Channel I r Oscilloscope t t d t t s f R t t off Channel II L ≥ 1 MΩ on C t t L ≤ 20 pF p Pulse duration s Storage time 50 Ω 100 Ω td Delay time t f Fall time tr Rise time t (= t off s + tf) Turn-off time 20688 ton (= td + tr) Turn-on time 96 11698 Fig. 2 - Test Circuit for ton and toff Fig. 3 - Switching Times
(Tamb = 25 °C, unless otherwise specified) 1000 2.0 V CE = 5 V I F = 20 mA 100 1.5 10 1.0 1 0.5 - Forward Current (mA) - Relative Current Transfer Ratio I F rel 0.1 0 0 0.4 0.8 CTR 1.2 1.6 2.0 - 25 0 25 50 75 100 96 11862 VF - Forward Voltage (V) 95 11089 T amb - Ambient Temperature (°C) Fig. 4 - Forward Current vs. Forward Voltage Fig. 5 - Relative Current Transfer Ratio vs. Ambient Temperature Rev. 2.0, 24-Aug-11
3
Document Number: 83764 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
