Datasheet E2B (Omron) - 9
ПроизводительOmron
ОписаниеCylindrical Proximity Sensor
Страниц / Страница22 / 9 — E2B. Size. M30. Sensing. Single. Double. distance. Type. Shielded. …
Формат / Размер файлаPDF / 6.9 Мб
E2B. Size. M30. Sensing. Single. Double. distance. Type. Shielded. Unshielded. Item. Model. E2B-M30. S10. N20. S15. N30. Sensing distance. Setting distance
E2B Size M30 Sensing Single Double distance Type Shielded Unshielded Item Model E2B-M30 S10 N20 S15 N30 Sensing distance Setting distance
5 предложений от 5 поставщиков
Датчик расстояния, Proximity Sensor NC NPN 2mm 10V to 30VDC 3Pin
E2B-S08KN02-MC-C2
888 ₽
E2B-S08KN02-MC-C2
Omron
2 146 ₽
ЧипСити
E2BS08KN02MCC2
Omron
2 184 ₽
E2BS08KN02MCC2
Omron
2 184 ₽
E2B
E2B Size M30 Sensing Single Double distance Type Shielded Unshielded Shielded Unshielded Item Model E2B-M30
S10 E2B-M30
N20 E2B-M30
S15 E2B-M30
10 mm ± 10% 20 mm ± 10% 15 mm ± 10% 30 mm ± 10%
Setting distance
0 to 8 mm 0 to 16 mm 0 to 11.25 mm 0 to 22.5 mm
Differential travel
10% max. of sensing distance
Detectable object
Ferrous metal (The sensing distance decreases with non-ferrous metal.)
Standard sensing object
30 × 30 × 1 mm 60 × 60 × 1 mm 45 × 45 × 1 mm 90 × 90 × 1 mm
(mild steel ST37) Response frequency (See note 1.)
400 Hz 100 Hz 250 Hz 100 Hz
Power supply voltage
10 to 30 VDC. (including 10% ripple (p-p))
Current consumption
10 mA max. -B models: PNP open collector
Output type
-C models: NPN open collector
Load current
200 mA max. (30 VDC max.)
Control output Residual voltage
2 V max. (under load current of 200 mA with cable length of 2 m)
Indicator
Operation indicator (Yellow LED)
Operation mode
-B1/-C1 models: NO
(with sensing object approaching)
-B2/-C2 models: NC Output reverse polarity protection, Power source circuit reverse polarity protection, Surge suppressor,
Protection circuit
Short-circuit protection
Ambient air temperature
Operation and storage : -25 to 70ºC (with no icing or condensation) ±10% max. of sensing distance at 23ºC within temperature range of -10 to 55ºC
Temperature influence
±15% max. of sensing distance at 23ºC within temperature range of -25 to 70ºC
Ambient humidity
Operation and Storage: 35 to 95%
Voltage influence
±1% max. of sensing distance in 24 VDC ±15%
Insulation resistance
50 MΩ min. (at 500 VDC) between current-carrying parts and case
Dielectric strength
1,000 VAC at 50/60 Hz for 1 min between current-carrying parts and case
Vibration resistance
10 to 55 Hz, 1.5-mm double amplitude for 2 hours each in X, Y and Z directions
Shock resistance
1,000 m/s2, 10 times each in X, Y and Z directions
Standard and listings
(1) IP67 (IEC60529) (2) EMC (EN60947-5-2) Pre-wired models (standard is 4 mm dia. PVC cable with length = 2 m, 5 m).
Connecting method
Connector models (M12-4pin)
Weight Pre-wired model
Short body: Approx. 160 g, Long body: Approx. 210 g (See note 2.)
(packaged) Connector model
Short body: Approx. 140 g, Long body: Approx. 160 g
Case
Brass-nickel plated
Sensing surface
PBT
Material Cable
Standard cable is 4 mm dia. PVC.
Clamping nut
Brass-nickel plated
Toothed washer
Zinc-plated iron Note: 1. The response frequency is an average value. Measurement conditions are as follows: standard sensing object, a distance of twice the standard sensing object between sensing objects, and a setting distance of half the sensing distance. 2. In case of ‘WP’ cable type.
9
