Datasheet LM317L (Fairchild) - 2
ПроизводительFairchild
Описание3-Terminal 0.1 A Positive Adjustable Regulator
Страниц / Страница8 / 2 — LM317L —. Block Diagram. 3-T. e rminal 0.1A. Voltage. Protection. …
Формат / Размер файлаPDF / 241 Кб
LM317L —. Block Diagram. 3-T. e rminal 0.1A. Voltage. Protection. Positiv. Reference. Circuitry. Adjust. ADJ. able. Figure 1. Block Diagram
LM317L — Block Diagram 3-T e rminal 0.1A Voltage Protection Positiv Reference Circuitry Adjust ADJ able Figure 1 Block Diagram
5 предложений от 5 поставщиков
LM317LZXA
64 ₽
LM317LZXA
76 ₽
LM317LZXA
Fairchild
LM317LZXA
Fairchild
Vi In n put 3
3-T e rminal 0.1A
Rlimit LIMIT 2 Vo
e
Output
Adjust
1 Vadj
ADJ able Figure 1. Block Diagram Absolute Maximum Ratings Regulator
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be opera- ble above the recommended operating conditions and stressing the parts to these levels is not recommended. In addi- tion, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TA = 25°C unless otherwise noted.
Symbol Parameter Value Unit
VI - VO Input-Output Voltage Differential 40 V PD Power Dissipation Internally limited W TJ Operating Junction Temperature Range 0 ~ +125 °C TSTG Storage Temperature Range -65 ~ +125 °C © 2002 Fairchild Semiconductor Corporation www.fairchildsemi.com LM317L Rev. 1.1.0 2
