Datasheet LM317 (Fairchild) - 5
ПроизводительFairchild
Описание3-Terminal Positive Adjustable Regulator
Страниц / Страница5 / 5 — LM317. Physical. Phys. ical. Di ensions. nsions. 3- T e rminal. Posi. …
Формат / Размер файлаPDF / 904 Кб
LM317. Physical. Phys. ical. Di ensions. nsions. 3- T e rminal. Posi. tive Adjust. able. Regul. ator. LIFE SUPPORT POLICY. www.fairchildsemi.com
LM317 Physical Phys ical Di ensions nsions 3- T e rminal Posi tive Adjust able Regul ator LIFE SUPPORT POLICY www.fairchildsemi.com
12 предложений от 11 поставщиков
IC REG LIN POS ADJ 1.5A D2PAK. Linear Voltage Regulator IC Positive Adjustable 1 Output 1.5A D²PAK. PMIC - Voltage Regulators...
LM317D2TXM
65 ₽
LM317D2TXM
Fairchild
LM317D2TXM
SUV System
LM317D2TXM
LM317
LM317 Physical Phys Di ical m Di ensions e
in
nsions
ch in es e ( s millim m et e e t rs) r s) un u l n ess oth t e h rwise r wise no n t o ed e ( d Con o tinu tin ed e ) d
Fairchild does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and Fairchild reserves the right at any time without notice to change said circuitry and specifications.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the device or system whose failure to perform can be rea- body, or (b) support or sustain life, and (c) whose failure sonably expected to cause the failure of the life support to perform when properly used in accordance with device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be rea- sonably expected to result in a significant injury to the
user. 5 www.fairchildsemi.com
