Datasheet AD8330 (Analog Devices) - 7
ОписаниеLow Cost, DC to 150 MHz, Variable Gain Amplifier
Страниц / Страница32 / 7 — Data Sheet. AD8330. TYPICAL PERFORMANCE CHARACTERISTICS. 2.0. NORMALIZED …
ВерсияH
Data Sheet. AD8330. TYPICAL PERFORMANCE CHARACTERISTICS. 2.0. NORMALIZED @ VDBS = 0.75V. 1.5. LO MODE. HI MODE. 1.0. 50MHz. 100MHz. B) d 0.5
Data Sheet AD8330 TYPICAL PERFORMANCE CHARACTERISTICS 2.0 NORMALIZED @ VDBS = 0.75V 1.5 LO MODE HI MODE 1.0 50MHz 100MHz B) d 0.5
39 предложений от 19 поставщиков
AD8330ACPZ-R7
356 ₽
AD8330ACPZ-R7
587 ₽
ЧипСити
AD8330ACPZ-R7
587 ₽
Зенер
Россия и страны ТС
AD8330ACPZ-R7
от 629 ₽
VS = 5 V, TA = 25°C, CL = 12 pF, VDBS = 0.75 V, VMODE = high (or O/C) VMAG = O/C (0.5 V), RL = ∞, VOFST = 0, differential operation, unless otherwise noted.
50 2.0 NORMALIZED @ VDBS = 0.75V 45 1.5 LO MODE HI MODE 40 1.0 35 50MHz 100MHz B) d 0.5 30 10MHz, 50MHz B) R ( d O N ( 25 R 0 R AI G 20 N E AI –0.5 G 15 1MHz 1MHz –1.0 10 10MHz 100MHz –1.5 5 0 –2.0 0 0.25 0.50 0.75 1.00 1.25 1.50
005
0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6
008
VDBS (V) V
03217-
DBS (V)
03217- Figure 4. Gain vs. VDBS Figure 7. Gain Error vs. VDBS at Various Frequencies
10 20 2340 UNITS 9 MODE = LO 15 8 TOR 10 C 7 FA 5 6 TION ITS A N 0 5 –30.6 –30.5 –30.4 –30.3 –30.2 –30.1 –30.0 –29.9 –29.8 –29.7 –29.6 –29.5 –29.4 –29.3 –29.2 –29.1 –29.0 LIC 20 4 OF U MODE = HI LTIP % U 15 M 3 IN 10 GA 2 1 5 0
006
0
009
0 1 2 3 4 5 29.1 29.2 29.3 29.4 29.5 29.6 29.7 29.8 29.9 30.0 30.1 30.2 30.3 30.4 30.5 30.6 V GAIN SCALING (mV/dB)
03217-
MAG (V)
03217- Figure 5. Linear Gain Multiplication Factor vs. VMAG Figure 8. Gain Slope Histogram
1.0 60 VDBS = 1.5V 0.8 50 1.2V 40 0.6 0.9V 30 0.4 0.6V B) 20 d 0.2 R ( T = –40°C B) 0.3V 10 O d R 0 R N ( 0V AI 0 N E –0.2 G AI T = +85°C –10 G –0.4 –20 T = +25°C –0.6 –30 –0.8 –40 –1.0 –50
007 010
0 2 . 0 0.4 0.6 0.8 0 . 1 1.2 4 . 1 1 6 . 100k 1M 10M 100M 500M V
03217-
DBS (V) FREQUENCY (Hz)
03217- Figure 6. Gain Linearity Error Normalized at 25°C vs. VDBS, Figure 9. Frequency Response in 10 dB Steps for Various Values of VDBS at Three Temperatures, f = 1 MHz Rev. G | Page 7 of 32 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Description Overall Structure Normal Operating Conditions Linear-in-dB Gain Control (VDBS) Inversion of the Gain Slope Gain Magnitude Control (VMAG) Two Classes of Variable Gain Amplifiers Amplitude/Phase Response Noise, Input Capacity, and Dynamic Range Dynamic Range Input Common-Mode Range and Rejection Ratio Output Noise and Peak Swing Offset Compensation Effects of Loading on Gain and AC Response Gain Errors Due to On-Chip Resistor Tolerances Output (Input) Common-Mode Control Using the AD8330 Gain and Swing Adjustments When Loaded Input Coupling DC-Coupled Signal Path Using Single-Sided Sources and Loads Pulse Operation Preserving Absolute Gain Calculation of Noise Figure Noise as a Function of VDBS Distortion Considerations P1dB and V1dB Applications Information ADC Driving Simple AGC Amplifier Wide Range True RMS Voltmeter Evaluation Board General Description Basic Operation Options Measurement Setup AD8330-EVALZ Board Design Outline Dimensions Ordering Guide
