Datasheet ADA4870 (Analog Devices) - 8
ОписаниеHigh Speed, High Voltage, 1 A Output Drive Amplifier
Страниц / Страница24 / 8 — ADA4870. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –20°C. +25°C. …
Формат / Размер файлаPDF / 668 Кб
ADA4870. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –20°C. +25°C. +100°C. N (. S = ±5V. S = ±20V. –12. OUT = 2V p-p. OUT = 20V p-p
ADA4870 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS –20°C +25°C +100°C N ( S = ±5V S = ±20V –12 OUT = 2V p-p OUT = 20V p-p
19 предложений от 11 поставщиков
Микросхема Операционный усилитель, IC OPAMP 1CH HS 1A 20PSOP3
ADA4870ARRZ-RL
792 ₽
ADA4870ARRZ-RL
1 600 ₽
ADA4870ARRZ-RL
от 3 057 ₽
ЗУМ-СМД
ADA4870ARRZ-RL
TCASE = 25°C, unless otherwise noted.
12 12 –20°C –20°C 9 +25°C 9 +25°C +100°C +100°C 6 6 3 3 0 0 B) B) d d –3 N ( N ( –3 AI AI G G –6 –6 –9 –9 V V S = ±5V S = ±20V –12 V V OUT = 2V p-p –12 OUT = 20V p-p R R F = 1.21kΩ F = 1.21kΩ A A –15 V = −2 –15 V = −2 C C L = 300pF L = 300pF R R S = 5Ω S = 5Ω –18 –18 1 10 100 1000
002
1 10 100 1000
017
FREQUENCY (MHz) FREQUENCY (MHz)
12125- 12125- Figure 4. Small Signal Frequency Response vs. Case Temperature, AV = −2, Figure 7. Large Signal Frequency Response vs. Case Temperature, AV = −2, VS = ±5 V, VOUT = 2 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω VS = ±20 V, VOUT = 20 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω
21 21 –20°C –20°C +25°C 18 +25°C 18 +100°C +100°C 15 15 12 12 9 9 B) B) d d 6 N ( N ( 6 AI AI G 3 G 3 0 0 VS = ±5V VS = ±20V –3 VOUT = 2V p-p –3 VOUT = 20V p-p RF = 1.21kΩ RF = 1.21kΩ A A –6 V = −5 V = −5 C –6 L = 300pF CL = 300pF RS = 5Ω RS = 5Ω –9 –9 1 10 100 1000
003
1 10 100 1000
018
FREQUENCY (MHz)
12125-
FREQUENCY (MHz)
12125- Figure 5. Small Signal Frequency Response vs. Case Temperature, AV = −5, Figure 8. Large Signal Frequency Response vs. Case Temperature, AV = −5, VS = ±5 V, VOUT = 2 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω VS = ±20 V, VOUT = 20 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω
27 27 –20°C –20°C +25°C 24 +25°C 24 +100°C +100°C 21 21 18 18 15 15 B) B) d d N ( 12 N ( 12 AI AI G 9 G 9 6 6 V V S = ±5V S = ±20V 3 V V OUT = 2V p-p 3 OUT = 20V p-p R R F = 1.21kΩ F = 1.21kΩ A 0 AV = −10 0 V = −10 C C L = 300pF L = 300pF R R S = 5Ω S = 5Ω –3 –3 1 10 100 1000
004
1 10 100 1000
019
FREQUENCY (MHz)
12125-
FREQUENCY (MHz)
12125- Figure 6. Small Signal Frequency Response vs. Case Temperature, AV = −10, Figure 9. Large Signal Frequency Response vs. Case Temperature, AV = −10, VS = ±5 V, VOUT = 2 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω VS = ±20 V, VOUT = 20 V p-p, RF = 1.21 kΩ, CL = 300 pF, RS = 5 Ω Rev. 0 | Page 8 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications ±20 V Supply ±5 V Supply Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information , Initial Power-Up, and Short-Circuit Thermal Protection Shutdown () Feedback Resistor Selection Capacitive Load Driving Heat and Thermal Management Power Dissipation Safe Operating Area Printed Circuit Board (PCB) Thermal Modeling Heat Sink Selection Power Supplies and Decoupling Composite Amplifier Outline Dimensions Ordering Guide
