Datasheet AD842 (Analog Devices) - 3
ОписаниеWideband, High Output Current, Fast Settling Op Amp
Страниц / Страница16 / 3 — Data Sheet. AD842. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±15 V …
ВерсияF
Формат / Размер файлаPDF / 362 Кб
Data Sheet. AD842. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±15 V OPERATION. boldface. Table 1. Test Conditions/
Data Sheet AD842 SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±15 V OPERATION boldface Table 1 Test Conditions/
13 предложений от 13 поставщиков
IC OPAMP GP 80MHZ 100MA 14CERDIP. Amplifier Circuit. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps
AD842SQ/883B
6 792 ₽
ЧипСити
AD842SQ/883B
6 792 ₽
727GS
AD842SQ/883B
AD842SQ/883B
link to page 9 link to page 9 link to page 3 link to page 3 link to page 3 link to page 3
TA = 25°C, unless otherwise specified. All minimum and maximum specifications are guaranteed. Specifications shown in
boldface
are tested on al production units.
Table 1. Test Conditions/ AD842JN/AD842JQ/AD842JR 1 AD842KN/AD842KQ AD842S Q Parameter Comments Min Typ Max Min Typ Max Min Typ Max Unit
INPUT OFFSET VOLTAGE2 0.5
1.5
0.3
1.0
0.5
1.5
mV TMIN to TMAX 2.5/2.5/3
1.5
3.5 mV Offset Drift 14 14 14 µV/°C INPUT BIAS CURRENT 4.2
8
3.5
5
4.2
8
µA TMIN to TMAX 10
6 12
µA Input Offset Current 0.1
0.4
0.05
0.2
0.1
0.4
µA TMIN to TMAX 0.5
0.3 0.6
µA INPUT CHARACTERISTICS Differential mode Input Resistance 100 100 100 kΩ Input Capacitance 2.0 2.0 2.0 pF INPUT VOLTAGE RANGE Common Mode
±10 ±10 ±10
V Common-Mode Rejection VCM = ±10 V
86
115
90
115
86
115 dB TMIN to TMAX 80
86 80
dB INPUT VOLTAGE NOISE f = 1 kHz 9 9 9 nV/√Hz Wideband Noise 10 Hz to 10 MHz 28 28 28 µV rms OPEN-LOOP GAIN VOUT = ±10 V RLOAD ≥ 499 Ω
40/40/30
90
50
90
40
90 V/mV TMIN to TMAX
20/20/15 25 20
V/mV OUTPUT CHARACTERISTICS Voltage RLOAD ≥ 499 Ω
±10 ±10 ±10
V Current VOUT = ±10 V
100 100 100
mA Open loop 5 5 5 Ω FREQUENCY RESPONSE Gain Bandwidth Product VOUT = 90 mV, 80 80 80 MHz AVCL = 2 Full Power Bandwidth3 VOUT = 20 V p-p, 4.7 6 4.7 6 4.7 6 MHz RLOAD ≥ 499 Ω Rise Time AVCL = −2 10 10 10 ns Overshoot AVCL = −2 20 20 20 % Slew Rate AVCL = −2 300 375 300 375 300 375 V/µs Settling Time4 10 V step To 0.1% 80 80 80 ns To 0.01% 100 100 100 ns Differential Gain f = 4.4 MHz 0.015 0.015 0.015 % Differential Phase f = 4.4 MHz 0.035 0.035 0.035 Degree POWER SUPPLY Rated Performance ±15 ±15 ±15 V Operating Range
±5 ±18 ±5 ±18 ±5 ±18
V Quiescent Current 13/13/14
14/14/16
13
14
13
14
mA TMIN to TMAX 16/16/19.5
16 19
mA Power Supply Rejection ±VS = ±5 V to
86
100
90
105
86
100 dB Ratio ±18 V TMIN to TMAX 80
86 80
dB 1 AD842JR specifications differ from those of the AD842JN and AD842JQ due to the thermal characteristics of the SOIC package. 2 Input offset voltage specifications are guaranteed after 5 minutes at TA = 25°C. 3 Full power bandwidth = slew rate/2 π V peak. 4 Refer to Figure 29 and Figure 30. Rev. F | Page 3 of 16 Document Outline Features Applications Connection Diagrams General Description Product Highlights Table of Contents Revision History Specifications Electrical Characteristics—±15 V Operation Absolute Maximum Ratings Thermal Characteristics ESD Caution Metalization Photograph Typical Performance Characteristics Theory of Operation Offset Nulling Settling Time Grounding and Bypassing Capacitive Load Driving Ability Using a Heat Sink Terminated Line Driver Overdrive Recovery Outline Dimensions Ordering Guide
