Клеммники KEEN SIDE
Datasheet ADP5300 (Analog Devices) - 6
Описание50 mA/500 mA, High Efficiency, Ultralow Power Step-Down Regulator
Страниц / Страница21 / 6 — ADP5300. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL …
ВерсияB
Формат / Размер файлаPDF / 746 Кб
ADP5300. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter Rating. Table 3. Thermal Resistance
ADP5300 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter Rating Table 3 Thermal Resistance
30 предложений от 12 поставщиков
ADP5300ACPZ-4-R7
от 47 ₽
ADP5300ACPZ-4-R7
207 ₽
Зенер
Россия и страны ТС
ADP5300ACPZ-4-R7
от 266 ₽
ADP5300ACPZ-4-R7
от 333 ₽
ADP5300 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device PVIN to PGND −0.3 V to +7 V soldered in a circuit board for surface-mount packages. θJC is SW to PGND −0.3 V to PVIN + 0.3 V the thermal resistance from the operating portion of the device FB to AGND −0.3 V to +7 V to the outside surface of the package (case) closest to the device VID to AGND −0.3 V to +7 V mounting area. EN to AGND −0.3 V to +7 V
VOUTOK to AGND −0.3 V to +7 V
Package Type θ
SYNC/MODE to AGND −0.3 V to +7 V
JA θJC Unit
STOP to AGND −0.3 V to +7 V 10-Lead, 3 mm × 3 mm LFCSP 57 0.86 °C/W PGND to AGND −0.3 V to +0.3 V Storage Temperate Range −65°C to +150°C
ESD CAUTION
Operating Temperature Range −40°C to +125°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. A | Page 6 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODES PWM Mode Hysteresis Mode Mode Selection OSILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY OPERATION ACTIVE DISCHARGE VOUTOK FUNCTION STOP SWITCHING THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
