Datasheet ADP5300 (Analog Devices) - 9
Описание50 mA/500 mA, High Efficiency, Ultralow Power Step-Down Regulator
Страниц / Страница21 / 9 — Data Sheet. ADP5300. 100. (%). FFIC. IN = 2.5V. IN = 3.0V. VIN = 3.0V. IN …
ВерсияB
Формат / Размер файлаPDF / 746 Кб
Data Sheet. ADP5300. 100. (%). FFIC. IN = 2.5V. IN = 3.0V. VIN = 3.0V. IN = 3.6V. VIN = 4.2V. VIN = 5.0V. VIN = 6.0V. 200. 300. 400. 500
Data Sheet ADP5300 100 (%) FFIC IN = 2.5V IN = 3.0V VIN = 3.0V IN = 3.6V VIN = 4.2V VIN = 5.0V VIN = 6.0V 200 300 400 500
24 предложений от 9 поставщиков
IC REG BUCK PROG 10LFCSP / Buck Switching Regulator IC Positive Programmable 0.8V 1 Output 50mA, 500mA 10-VFDFN Exposed Pad, CSP...
ADP5300ACPZ-4-R7
от 96 ₽
ADP5300ACPZ-4-R7
144 ₽
727GS
ADP5300ACPZ-4-R7
от 570 ₽
ADP5300ACPZ-4-R7
Data Sheet ADP5300 100 100 90 90 80 80 70 70 (%) 60 (%) 60 Y Y C C N 50 N 50 IE IE FFIC 40 FFIC 40 E V E V IN = 2.5V IN = 2.5V 30 V 30 IN = 3.0V VIN = 3.0V V V 20 IN = 3.6V 20 IN = 3.6V VIN = 4.2V VIN = 4.2V 10 VIN = 5.0V 10 VIN = 5.0V VIN = 6.0V VIN = 6.0V 0 0 0 100 200 300 400 500
010
013
LOAD CURRENT (mA)
13366-
LOAD CURRENT (mA)
13366- Figure 10. PWM Efficiency vs. Load Current, VOUT = 1.5 V Figure 13. PWM Efficiency vs. Load Current, VOUT = 1.8 V
100 100 90 90 80 80 70 70 (%) 60 (%) 60 Y Y C C N 50 N 50 IE IE FFIC 40 FFIC 40 E E 30 V 30 IN = 3.0V V VIN = 3.6V 20 IN = 3.6V 20 V V IN = 4.2V IN = 4.2V V 10 VIN = 5.0V 10 IN = 5.0V V V IN = 6.0V IN = 6.0V 0
1 1
0
014
LOAD CURRENT (mA)
13366-
LOAD CURRENT (mA)
13366- Figure 11. PWM Efficiency vs. Load Current, VOUT = 2.5 V Figure 14. PWM Efficiency vs. Load Current, VOUT = 3.3 V
160 350 140 –40ºC –40ºC +25ºC +25ºC 300 +85ºC +85ºC A) 120 A) n +125ºC n +125ºC ( ( NT NT 100 250 80 CURRE N CURRE NT W 200 60 CE DO S E HUT UI S 40 Q 150 20 0 100
015
2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5
012
2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 V V IN (V) IN (V)
13366- 13366- Figure 12. Shutdown Current vs. VIN, EN = Low Figure 15. Hysteresis Quiescent Current vs. VIN, SYNC/MODE = Low Rev. A | Page 9 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODES PWM Mode Hysteresis Mode Mode Selection OSILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY OPERATION ACTIVE DISCHARGE VOUTOK FUNCTION STOP SWITCHING THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
