Линейка продуктов KEEN SIDE
Datasheet PIC10F200, PIC10F202, PIC10F204, PIC10F206 (Microchip) - 6
ПроизводительMicrochip
Описание6-Pin, 8-Bit Flash Microcontrollers
Страниц / Страница88 / 6 — PIC10F200/202/204/206. 3.0 ARCHITECTURAL OVERVIEW The high performance of …
PIC10F200/202/204/206. 3.0 ARCHITECTURAL OVERVIEW The high performance of the PIC10F200/202/204/206
PIC10F200/202/204/206 3.0 ARCHITECTURAL OVERVIEW The high performance of the PIC10F200/202/204/206
PIC10F204T-E/OTVAO
44 ₽
devices can be attributed to a number of architectural
features commonly found in RISC microprocessors. To
begin with, the PIC10F200/202/204/206 devices use a
Harvard architecture in which program and data are
accessed on separate buses. This improves
bandwidth over traditional von Neumann architectures
where program and data are fetched on the same bus.
Separating program and data memory further allows
instructions to be sized differently than the 8-bit wide
data word. Instruction opcodes are 12 bits wide,
making it possible to have all single-word instructions.
A 12-bit wide program memory access bus fetches a
12-bit instruction in a single cycle. A two-stage pipeline
overlaps fetch and execution of instructions.
Consequently, all instructions (33) execute in a single
cycle (1 s @ 4 MHz) except for program branches.
The table below lists program memory (Flash) and data
memory (RAM) for the PIC10F200/202/204/206
devices. TABLE 3-1: PIC10F2XX MEMORY The PIC10F200/202/204/206 devices contain an 8-bit
ALU and working register. The ALU is a general
purpose arithmetic unit. It performs arithmetic and
Boolean functions between data in the working register
and any register file.
The ALU is 8 bits wide and capable of addition,
subtraction, shift and logical operations. Unless
otherwise mentioned, arithmetic operations are two’s
complement in nature. In two-operand instructions, one
operand is typically the W (working) register. The other
operand is either a file register or an immediate
constant. In single operand instructions, the operand is
either the W register or a file register.
The W register is an 8-bit working register used for ALU
operations. It is not an addressable register.
Depending on the instruction executed, the ALU may
affect the values of the Carry (C), Digit Carry (DC) and
Zero (Z) bits in the STATUS register. The C and DC bits
operate as a borrow and digit borrow out bit,
respectively, in subtraction. See the SUBWF and ADDWF
instructions for examples.
A simplified block diagram is shown in Figure 3-1 and
Figure 3-2, with the corresponding device pins
described in Table 3-2. Memory
Device
Program Data PIC10F200 256 x 12 16 x 8 PIC10F202 512 x 12 24 x 8 PIC10F204 256 x 12 16 x 8 PIC10F206 512 x 12 24 x 8 The PIC10F200/202/204/206 devices can directly or
indirectly address its register files and data memory. All
Special Function Registers (SFR), including the PC,
are mapped in the data memory. The PIC10F200/202/
204/206 devices have a highly orthogonal
(symmetrical) instruction set that makes it possible to
carry out any operation, on any register, using any
addressing mode. This symmetrical nature and lack of
“special optimal situations” make programming with the
PIC10F200/202/204/206 devices simple, yet efficient.
In addition, the learning curve is reduced significantly. DS40001239F-page 6  2004-2014 Microchip Technology Inc.
