Datasheet LM4040-N, LM4040-N-Q1 (Texas Instruments) - 8
Страниц / Страница | 71 / 8 — LM4040-N,. LM4040-N-Q1. www.ti.com |
Версия | K |
Формат / Размер файла | PDF / 1.8 Мб |
Язык документа | английский |
67 предложений от 32 поставщиков Микросхемы питания.Тип: Прецизионный микромощный источник опорного напряжения серии LM440-NВходное напряжение: cерия VREF - 2,5 (max) ВВыходное напряжение: 2,5 ± 0,1% ВВыходной... |
| LM4040AIM3-2.5 Texas Instruments | 57 ₽ | |
| LM4040AIM3-2.5+T Maxim | по запросу | |
| LM4040AIM3-2.5+T ProsKit | по запросу | |
| LM4040AIM3-2.5 Texas Instruments | по запросу | |
SNOS633K – OCTOBER 2000 – REVISED JUNE 2016
www.ti.com 6.6 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'I'
all other limits TA = TJ = 25°C. The grades C, D and E designate initial Reverse Breakdown Voltage tolerances of ±0.5%, ±1% and ±2%, respectively.
PARAMETER TEST CONDITIONS MIN(1) TYP(2) MAX(1) UNIT
Reverse Breakdown I Voltage R = 100 μA 2.048 V LM4040CIM3 TA = TJ = 25°C ±10 LM4040CIZ LM4040CIM7 TA = TJ = TMIN to TMAX ±23 VR Reverse Breakdown LM4040DIM3 TA = TJ = 25°C ±20 mV Voltage Tolerance(3) IR = 100 μA LM4040DIZ LM4040DIM7 TA = TJ = TMIN to TMAX ±40 LM4040EIZ TA = TJ = 25°C ±41 LM4040EIM7 TA = TJ = TMIN to TMAX ±60 LM4040CIM3 TA = TJ = 25°C 45 60 LM4040CIZ LM4040CIM7 TA = TJ = TMIN to TMAX 65 Minimum Operating LM4040DIM3 TA = TJ = 25°C 45 65 IRMIN μA Current LM4040DIZ LM4040DIM7 TA = TJ = TMIN to TMAX 70 LM4040EIZ TA = TJ = 25°C 45 65 LM4040EIM7 TA = TJ = TMIN to TMAX 70 IR = 10 mA ±20 LM4040CIM3 TA = TJ = 25°C ±15 LM4040CIZ LM4040CIM7 TA = TJ = TMIN to TMAX ±100 Average Reverse Breakdown Voltage LM4040DIM3 TA = TJ = 25°C ±15 ΔVR/ΔT I ppm/°C Temperature R = 1 mA LM4040DIZ T Coefficient(3) LM4040DIM7 A = TJ = TMIN to TMAX ±150 LM4040EIZ TA = TJ = 25°C ±15 LM4040EIM7 TA = TJ = TMIN to TMAX ±150 IR = 100 μA ±15 (1) Limits are 100% production tested at 25°C. Limits over temperature are ensured through correlation using Statistical Quality Control (SQC) methods. The limits are used to calculate AOQL. (2) Typicals are at TJ = 25°C and represent most likely parametric norm. (3) The overtemperature limit for Reverse Breakdown Voltage Tolerance is defined as the room temperature Reverse Breakdown Voltage Tolerance ±[(ΔVR/ΔT)(maxΔT)(VR)]. Where, ΔVR/ΔT is the VR temperature coefficient, maxΔT is the maximum difference in temperature from the reference point of 25°C to T MIN or TMAX, and VR is the reverse breakdown voltage. The total overtemperature tolerance for the different grades in the industrial temperature range where maxΔT = 65°C is shown below: A-grade: ±0.75% = ±0.1% ±100 ppm/°C × 65°C B-grade: ±0.85% = ±0.2% ±100 ppm/°C × 65°C C-grade: ±1.15% = ±0.5% ±100 ppm/°C × 65°C D-grade: ±1.98% = ±1.0% ±150 ppm/°C × 65°C E-grade: ±2.98% = ±2.0% ±150 ppm/°C × 65°C The total overtemperature tolerance for the different grades in the extended temperature range where max ΔT = 100 °C is shown below: C-grade: ±1.5% = ±0.5% ±100 ppm/°C × 100°C D-grade: ±2.5% = ±1.0% ±150 ppm/°C × 100°C E-grade: ±3.5% = ±2.0% ±150 ppm/°C × 100°C Therefore, as an example, the A-grade 2.5-V LM4040-N has an overtemperature Reverse Breakdown Voltage tolerance of ±2.5V × 0.75% = ±19 mV. 8 Submit Documentation Feedback Copyright © 2000–2016, Texas Instruments Incorporated Product Folder Links: LM4040-N LM4040-N-Q1 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.6 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'I' 6.7 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' 6.8 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' (AEC Grade 3) 6.9 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'C', 'D', and 'E'; Temperature Grade 'I' (AEC Grade 3) 6.10 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' (AEC Grade 1) 6.11 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.12 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'I' 6.13 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' 6.14 Electrical Characteristics: 4.1-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.15 Electrical Characteristics: 4.1-V LM4040-N VR Tolerance Grades 'C' and 'D'; Temperature Grade 'I' 6.16 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.17 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.18 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'E' 6.19 Electrical Characteristics: 8.2-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.20 Electrical Characteristics: 8.2-V Lm4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.21 Electrical Characteristics: 10-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.22 Electrical Characteristics: 10-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.23 Typical Characteristics 6.23.1 Start-Up Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Shunt Regulator 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curve 9.2.2 4.1-V ADC Application 9.2.2.1 Design Requirements 9.2.2.2 Detailed Design Procedure 9.2.3 Bounded Amplifier 9.2.3.1 Design Requirements 9.2.3.2 Detailed Design Procedure 9.2.4 Protecting Op-Amp Input 9.2.4.1 Design Requirements 9.2.4.2 Detailed Design Procedure 9.2.5 Precision ±4.096-V Reference 9.2.5.1 Design Requirements 9.2.5.2 Detailed Design Procedure 9.2.6 Precision Current Sink/Source 9.2.6.1 Design Requirements 9.2.6.2 Detailed Design Procedure 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Community Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, And Orderable Information 13.1 SOT-23 and SC70 Package Marking Information
