Datasheet LM6181 (Texas Instruments) - 5
Описание | 100 mA, 100 MHz Current Feedback Amplifier |
Страниц / Страница | 39 / 5 — LM6181. www.ti.com. 6.5 ±15V DC Electrical Characteristics. Boldface. … |
Версия | C |
Формат / Размер файла | PDF / 2.1 Мб |
Язык документа | английский |
LM6181. www.ti.com. 6.5 ±15V DC Electrical Characteristics. Boldface. PARAMETER. TEST CONDITIONS. LM6181AM. LM6181AI. LM6181I. UNIT. TYP(1)
15 предложений от 14 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM6181IN/NOPB Operational Amplifier, Single, 1 Amplifier, 100MHz, 1400V/µs, 7V to 32V, DIP, 8Pins |
| LM6181IN/NOPB Texas Instruments | 128 ₽ | |
| LM6181IN/NOPB Rochester Electronics | 142 ₽ | |
| LM6181INNOPB Texas Instruments | по запросу | |
| LM6181IN/NOPB Rochester Electronics | по запросу | |
LM6181 www.ti.com
SNOS634C – MAY 1998 – REVISED SEPTEMBER 2014
The following specifications apply for Supply Voltage = ±15V, RF = 820 Ω, and RL = 1 kΩ unless otherwise noted.
Boldface
limits apply at the temperature extremes.
PARAMETER TEST CONDITIONS LM6181AM LM6181AI LM6181I UNIT TYP(1) LIMIT(2) TYP(1) LIMIT(2) TYP(1) LIMIT(2)
VOS Input Offset Voltage 3.0 3.0 5.0 mV 2.0 2.0 3.5
4.0 3.5 5.5
max TC VOS Input Offset Voltage Drift 5.0 5.0 5.0 μV/°C IB Inverting Input Bias 5.0 5.0 10 2.0 2.0 5.0 Current
12.0 12.0 17.0
μA max Non-Inverting Input Bias 1.5 1.5 3.0 0.5 0.5 2.0 Current
3.0 3.0 5.0
TC IB Inverting Input Bias 30 30 30 Current Drift nA/°C Non-Inverting Input Bias 10 10 10 Current Drift IB Inverting Input Bias VS = ±4.5V, ±16V 0.5 0.5 0.75 PSR Current Power Supply 0.3 0.3 0.3
3.0 3.0 4.5
Rejection Non-Inverting Input Bias VS = ±4.5V, ±16V 0.5 0.5 0.5 Current Power Supply 0.05 0.05 0.05
1.5 1.5 3.0
Rejection μA/V max IB Inverting Input Bias −10V ≤ VCM ≤ +10V 0.5 0.5 0.75 CMR Current Common Mode 0.3 0.3 0.3
0.75 0.75 1.0
Rejection Non-Inverting Input Bias −10V ≤ VCM ≤ +10V 0.5 0.5 0.5 Current Common Mode 0.1 0.1 0.1
0.5 0.5 0.5
Rejection CMRR Common Mode −10V ≤ VCM ≤ +10V 50 50 50 dB 60 60 60 Rejection Ratio
50 50 50
min PSRR Power Supply Rejection VS = ±4.5V, ±16V 70 70 70 dB 80 80 80 Ratio
70 70 65
min RO Output Resistance AV = −1, f = 300 kHz 0.2 0.2 0.2 Ω RIN Non-Inverting Input MΩ 10 10 10 Resistance min VO Output Voltage Swing RL = 1 kΩ 11 11 11 12 12 12
11 11 11
V min RL = 100Ω 10 10 10 11 11 11
7.5 8.0 8.0
ISC Output Short Circuit 100 100 100 mA 130 130 130 Current
75 85 85
min ZT Transimpedance RL = 1 kΩ 1.0 1.0 0.8 1.8 1.8 1.8
0.5 0.5 0.4
MΩ min RL = 100Ω 0.8 0.8 0.7 1.4 1.4 1.4
0.4 0.4 0.35
IS Supply Current No Load, VO = 0V 10 10 10 mA 7.5 7.5 7.5
10 10 10
max VCM Input Common Mode V+ − 1.7 V+ − 1.7 V+ − 1.7 V Voltage Range V− + 1.7 V− + 1.7 V− + 1.7 (1) Typical values represent the most likely parametric norm. (2) All limits ensured at room temperature (standard type face) or at operating temperature extremes
(bold face type)
. Copyright © 1998–2014, Texas Instruments Incorporated Submit Documentation Feedback 5 Product Folder Links: LM6181 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 Handling Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 ±15V DC Electrical Characteristics 6.6 ±15V AC Electrical Characteristics 6.7 ±5V DC Electrical Characteristics 6.8 ±5V AC Electrical Characteristics 6.9 Typical Performance Characteristics 7 Typical Applications 7.1 Current Feedback Topology 7.2 Power Supply Bypassing and Layout Considerations 7.3 Feedback Resistor Selection: Rf 7.4 Slew Rate Considerations 7.5 Driving Capacitive Loads 7.6 Capacitive Feedback 8 Application and Implementation 8.1 Typical Application 8.1.1 Typical Performance Characteristics 8.1.1.1 Overdrive Recovery 9 Device and Documentation Support 9.1 Trademarks 9.2 Electrostatic Discharge Caution 9.3 Glossary 10 Mechanical, Packaging, and Orderable Information
