Datasheet LM158, LM158A, LM258, LM258A, LM358, LM358A, LM2904, LM2904V (Texas Instruments) - 5
ОписаниеDual Operational Amplifiers
Страниц / Страница43 / 5 — LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. …
ВерсияU
Формат / Размер файлаPDF / 2.0 Мб
LM158,. LM158A, LM258. , LM258A. LM358,. LM358A,. LM2904. , LM2904V. www.ti.com. 6.4 Thermal Information. LMx58, LMx58x, LM2904V, LM2904
LM158, LM158A, LM258 , LM258A LM358, LM358A, LM2904 , LM2904V www.ti.com 6.4 Thermal Information LMx58, LMx58x, LM2904V, LM2904
SLOS068U – JUNE 1976 – REVISED JANUARY 2017
6.4 Thermal Information LMx58, LMx58x, LM2904V, LM2904 LMx58, LMx58, LMx58x, LMx58x, LM2904 LM2904 V V THERMAL METRIC(1) UNIT D (SOIC) DGK P (PDIP) PS (SO) PW FK JG (VSSOP) (TSSOP) (LCCC) (CDIP) 8 PINS 8 PINS 8 PINS 8 PINS 8 PINS 20 PINS 8 PINS
RθJA Junction-to-ambient 97 172 85 95 149 — — °C/W thermal resistance RθJC(top) Junction-to-case (top) thermal 72.2 — — — — 5.61 14.5 °C/W resistance (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report.
6.5 Electrical Characteristics for LMx58
at specified free-air temperature, VCC = 5 V (unless otherwise noted)
LM158 LM358 PARAMETER TEST CONDITIONS(1) T (2) LM258 A UNIT MIN TYP(3) MAX MIN TYP(3) MAX
VCC = 5 V to MAX, 25°C 3 5 3 7 V V IO Input offset voltage IC = VICR(min), mV V Full range 7 9 O = 1.4 V Average temperature coefficient of αVIO Full range 7 7 µV/°C input offset voltage 25°C 2 30 2 50 IIO Input offset current VO = 1.4 V nA Full range 100 150 Average temperature coefficient of αIIO Full range 10 10 pA/°C input offset current 25°C –20 –150 –20 –250 IIB Input bias current VO = 1.4 V nA Full range –300 –500 0 to 0 to 25°C VCC – 1.5 VCC – 1.5 VICR Common-mode input voltage range VCC = 5 V to MAX V 0 to 0 to Full range VCC – 2 VCC – 2 RL ≥ 2 kΩ 25°C VCC – 1.5 VCC – 1.5 RL ≥ 10 kΩ 25°C VOH High-level output voltage V RL = 2 kΩ Full range 26 26 VCC = MAX RL ≥ 10 kΩ Full range 27 28 27 28 VOL Low-level output voltage RL ≤ 10 kΩ Full range 5 20 5 20 mV V 25°C 50 100 25 100 Large-signal differential CC = 15 V A V VD V/mV voltage amplification O = 1 V to 11 V, R Full range 25 15 L ≥ 2 kΩ V CMRR Common-mode rejection ratio CC= 5 V to MAX, 25°C 70 80 65 80 dB VIC = VICR(min) Supply-voltage rejection ratio kSVR V (ΔV CC = 5 V to MAX 25°C 65 100 65 100 dB DD /ΔVIO) VO1/ VO2 Crosstalk attenuation f = 1 kHz to 20 kHz 25°C 120 120 dB VCC = 15 V, 25°C –20 –30 –20 –30 VID = 1 V, Source V Full range –10 –10 O = 0 mA IO Output current VCC = 15 V, 25°C 10 20 10 20 VID = –1 V, Sink V Full range 5 5 O = 15 V VID = –1 V, VO = 200 mV 25°C 12 30 12 30 μA V I CC at 5 V, GND at –5 V, OS Short-circuit output current 25°C ±40 ±60 ±40 ±60 mA VO = 0 (1) All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for LM2902 and 30 V for the others. (2) Full range is –55°C to 125°C for LM158, –25°C to 85°C for LM258, and 0°C to 70°C for LM358, and –40°C to 125°C for LM2904. (3) All typical values are at TA = 25°C Copyright © 1976–2017, Texas Instruments Incorporated Submit Documentation Feedback 5 Product Folder Links: LM158 LM258 LM258A LM358 LM358A LM2904 LM2904V Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for LMx58 6.6 Electrical Characteristics for LM2904 6.7 Electrical Characteristics for LM158A and LM258A 6.8 Electrical Characteristics for LM358A 6.9 Operating Conditions 6.10 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Unity-Gain Bandwidth 8.3.2 Slew Rate 8.3.3 Input Common Mode Range 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
