Datasheet TLC2272, TLC2272A, TLC2272M, TLC2272AM, TLC2274, TLC2274A, TLC2274M, TLC2274AM (Texas Instruments) - 8
ОписаниеTLC227x, TLC227xA: Advanced LinCMOS Rail-to-Rail Operational Amplifiers datasheet
Страниц / Страница55 / 8 — TLC2272. , TLC2272A. , TLC2272M. , TLC2272AM. TLC2274. , TLC2274A. , …
ВерсияH
Формат / Размер файлаPDF / 2.4 Мб
TLC2272. , TLC2272A. , TLC2272M. , TLC2272AM. TLC2274. , TLC2274A. , TLC2274M. , TLC2274AM. www.ti.com
TLC2272 , TLC2272A , TLC2272M , TLC2272AM TLC2274 , TLC2274A , TLC2274M , TLC2274AM www.ti.com
SLOS190H – FEBRUARY 1997 – REVISED MARCH 2016
www.ti.com 6.6 TLC2272 and TLC2272A Electrical Characteristics VDD± = ±5 V
at specified free-air temperature, VDD± = ±5 V; TA = 25°C, unless otherwise noted.
PARAMETER TEST CONDITIONS MIN TYP MAX UNIT
TLC2272 300 2500 TA = 25°C V TLC2272A 300 950 V IC = 0 V, VO = 0 V, IO Input offset voltage µV RS = 50 Ω TLC2272 3000 Full Range(1) TLC2272A 1500 Temperature coefficient of αVIO V input offset voltage IC = 0 V, VO = 0 V, RS = 50 Ω 2 μV/°C Input offset voltage long-term drift(2) VIC = 0 V, VO = 0 V, RS = 50 Ω 0.002 μV/mo All level parts TA = 25°C 0.5 60 C level part TA = 0°C to 80°C 100 V I IC = 0 V, VO = 0 V, IO Input offset current I level part T pA R A = –40°C to 85°C 150 S = 50 Ω Q level part TA = –40°C to 125°C 800 M level part TA = –55°C to 125°C 800 All level parts TA = 25°C 1 60 C level part TA = 0°C to 80°C 100 V I IC = 0 V, VO = 0 V, IB Input bias current I level part T pA R A = –40°C to 85°C 150 S = 50 Ω Q level part TA = –40°C to 125°C 800 M level part TA = –55°C to 125°C 800 TA = 25°C –5.3 0 4 VICR Common-mode input voltage RS = 50 Ω; |VIO | ≤ 5 mV V Full Range(1) –5 0 3.5 IO = −20 μA 4.99 TA = 25°C 4.85 4.93 Maximum positive peak IO = −200 μA VOM+ Full Range(1) 4.85 V output voltage TA = 25°C 4.25 4.65 IO = −1 mA Full Range(1) 4.25 IO = 50 μA –4.99 TA = 25°C –4.85 –4.91 Maximum negative IO = 500 μA VOM- V Full Range(1) –4.85 V peak output voltage IC = 0 V, TA = 25°C –3.5 –4.1 IO = 5 mA Full Range(1) –3.5 TA = 25°C 25 50 C level part TA = 0°C to 80°C 25 TA = 25°C 25 50 I level part TA = –40°C to 85°C 25 Large-signal differential VO = ±4 V; RL = 10 kΩ AVD T V/mV voltage amplification A = 25°C 20 50 Q level part TA = –40°C to 125°C 20 TA = 25°C 20 50 M level part TA = –55°C to 125°C 20 VO = ±4 V; RL = 1 MΩ 300 rid Differential input resistance 1012 Ω ri Common-mode input resistance 1012 Ω ci Common-mode input capacitance f = 10 kHz, P package 8 pF zo Closed-loop output impedance f = 1 MHz, AV = 10 130 Ω V TA = 25°C 75 80 CMRR Common-mode rejection ratio IC = –5 V to 2.7 V, dB VO = 0 V, RS = 50 Ω Full Range(1) 75 Supply-voltage rejection ratio V TA = 25°C 80 95 k DD+ = 2.2 V to ±8 V, SVR dB (ΔVDD / ΔVIO) VIC = 0 V, no load Full Range(1) 80 TA = 25°C 2.4 3 IDD Supply currrent VO = 0 V, no load mA Full Range(1) 3 (1) TA = –55°C to 125°C. (2) Typical values are based on the input offset voltage shift observed through 168 hours of operating life test at TA = 150°C extrapolated to TA = 25°C using the Arrhenius equation and assuming an activation energy of 0.96 eV. 8 Submit Documentation Feedback Copyright © 1997–2016, Texas Instruments Incorporated Product Folder Links: TLC2272 TLC2272A TLC2272M TLC2272AM TLC2274 TLC2274A TLC2274M TLC2274AM Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 TLC2272 and TLC2272A Electrical Characteristics VDD = 5 V 6.6 TLC2272 and TLC2272A Electrical Characteristics VDD± = ±5 V 6.7 TLC2274 and TLC2274A Electrical Characteristics VDD = 5 V 6.8 TLC2274 and TLC2274A Electrical Characteristics VDD± = ±5 V 6.9 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.1.1 Macromodel Information 8.2 Typical Application 8.2.1 High-Side Current Monitor 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Related Links 11.2 Community Resources 11.3 Trademarks 11.4 Electrostatic Discharge Caution 11.5 Glossary 12 Mechanical, Packaging, and Orderable Information
