Datasheet TS5A22362 (Texas Instruments) - 5
ОписаниеTS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability
Страниц / Страница32 / 5 — TS5A22362. www.ti.com. 6.4 Thermal Information. THERMAL METRIC (1). DGS …
ВерсияC
TS5A22362. www.ti.com. 6.4 Thermal Information. THERMAL METRIC (1). DGS (VSSOP). DRC (VSON). YZP (DSBGA). UNIT. 10 PINS
TS5A22362 www.ti.com 6.4 Thermal Information THERMAL METRIC (1) DGS (VSSOP) DRC (VSON) YZP (DSBGA) UNIT 10 PINS
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 13 link to page 14 link to page 12
SCDS364D – JUNE 2015 – REVISED MARCH 2018
6.4 Thermal Information TS5A22362 THERMAL METRIC (1) DGS (VSSOP) DRC (VSON) YZP (DSBGA) UNIT 10 PINS 10 PINS 10 PINS
RθJA Junction-to-ambient thermal resistance 163.3 44.3 90.9 °C/W RθJC(top) Junction-to-case (top) thermal resistance 56.4 70.1 0.3 °C/W RθJB Junction-to-board thermal resistance 83.1 19.3 8.3 °C/W ψJT Junction-to-top characterization parameter 6.8 2.0 3.2 °C/W ψJB Junction-to-board characterization parameter 81.8 19.4 8.3 °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report.
6.5 Electrical Characteristics for 2.5-V Supply
VCC = 2.3 V to 2.7 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT Analog Switch
VCOM, Analog signal V V CC – 5.5 VCC V NO, VNC range V 25°C 0.65 0.94 ON-state NC or VNO = VCC, 1.5 V, COM to NO or NC, Ron V 2.7 V Ω resistance CC – 5.5 V see Figure 13 I Full 1.3 COM = –100 mA, ON-state 25°C 0.023 0.11 V COM to NO or NC, ΔR NC or VNO = 1.5 V, on resistance match 2.7 V Ω I see Figure 13 between channels COM = –100 mA, Full 0.15 ON-state VNC or VNO = VCC, 1.5 V, 25°C 0.18 0.46 COM to NO or NC, Ron(flat) resistance VCC – 5.5 V 2.7 V Ω see Figure 13 flatness I Full 0.5 COM = –100 mA, VNC = 2.25 V, VCC – 5.5 V 25°C –50 50 VCOM = VCC – 5.5 V, 2.25 V VNO = Open NC, NO COM to NO INC(OFF), OFF leakage or See Figure 14 2.7 nA INO(OFF) current V Full –375 375 NO = 2.25 V, VCC – 5.5 V, VCOM = VCC – 5.5 V, 2.25 V VNC = Open COM to NC COM 25°C –50 50 V I NC and VNO = Floating, COM(ON) ON leakage See Figure 15 2.7 V nA V current COM = VCC,VCC – 5.5 V Full –375 375
Digital Control Inputs (IN) (2)
VIH Input logic high 1.4 5.5 Full V VIL Input logic low 0.6 Input leakage 25°C –250 250 IIH, IIL V 2.7 V nA current IN = VCC or 0 Full –250 250
Dynamic
25°C 2.5 V 44 80 V C t COM = VCC, L = 35 pF, ON Turnon time ns R 2.3 V to 2.7 L = 300 Ω, see Figure 17 Full 120 V 25°C 2.5 V 22 70 V C t COM = VCC, L = 35 pF, OFF Turnoff time ns R 2.3 V to 2.7 L = 300 Ω, see Figure 17 Full 70 V Break-before-make tBBM See Figure 18 25°C 2.5 V 1 7 ns time V C Q GEN = 0, L = 1 nF, C Charge injection 25°C 2.5 V 150 pC RGEN = 0, see Figure 22 CNC(OFF), NC, NO V C NC or VNO = VCC or GND, See Figure 16 25°C 2.5 V 70 pF NO(OFF) OFF capacitance (1) The algebraic convention, whereby the most negative value is a minimum and the most positive value is a maximum (2) All unused digital inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, SCBA004. Copyright © 2015–2018, Texas Instruments Incorporated Submit Documentation Feedback 5 Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
