Datasheet OPA2333, OPA333 (Texas Instruments) - 10
ОписаниеOPAx333 1.8-V, microPower, CMOS Operational Amplifiers, Zero-Drift
Страниц / Страница45 / 10 — OPA333. , OPA2333. www.ti.com. Figure 9. Quiescent Current vs …
ВерсияE
OPA333. , OPA2333. www.ti.com. Figure 9. Quiescent Current vs Temperature. Figure 10. Large-Signal Step Response
OPA333 , OPA2333 www.ti.com Figure 9 Quiescent Current vs Temperature Figure 10 Large-Signal Step Response
59 предложений от 25 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA333AIDBVR Operational Amplifier, Zero-Drift, 1 Amplifier, 350kHz, 0.16V/µs, ± 0.9V to ± 2.75V, 1.8V to 5.5V...
Элитан
OPA333AIDBVR
36 ₽
OPA333AIDBVR
110 ₽
OPA333AIDBVR
от 344 ₽
OPA333AIDBVR
OPA333
OPA333 , OPA2333
SBOS351E – MARCH 2006 – REVISED DECEMBER 2015
www.ti.com
At TA = 25°C, VS = 5 V, and CL = 0 pF, unless otherwise noted. 25 G = 1 R = 10 kW L 20 V = 5.5 V S 15 A) (m V = 1.8 V S I Q 10 oltage (1 V/div) 5 Output V 0 -50 -25 0 25 50 75 100 125 Temperature ( C) ° Time (50 ms/div)
Figure 9. Quiescent Current vs Temperature Figure 10. Large-Signal Step Response
G = +1 R = 10 kW L 2 V/div 0 Input Output 10 kW oltage (50 mV/div) +2.5 V 1 kW 0
OPA333
Output V 1 V/div -2.5 V Time (5 ms/div) Time (50 ms/div)
Figure 11. Small-Signal Step Response Figure 12. Positive Overvoltage Recovery
600 4-V Step 500 Input s) m 400 2 V/div 0 ime ( T 300 0 10 kW 1 V/div 200 +2.5 V Settling 1 kW 0.001% Output 100
OPA333
0.01% -2.5 V 0 1 10 100 Time (50 ms/div) Gain (dB)
Figure 13. Negative Overvoltage Recovery Figure 14. Settling Time vs Closed-Loop Gain
10 Submit Documentation Feedback Copyright © 2006–2015, Texas Instruments Incorporated Product Folder Links: OPA333 OPA2333 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA333 6.5 Thermal Information: OPA2333 6.6 Electrical Characteristics 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Operating Voltage 7.3.2 Input Voltage 7.3.3 Internal Offset Correction 7.3.4 Achieving Output Swing to the Op Amp Negative Rail 7.3.5 DFN Package 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 High-Side Voltage-to-Current (V-I) Converter 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curve 8.2.2 Precision, Low-Level Voltage-to-Current (V-I) Converter 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 8.2.2.3 Application Curves 8.2.3 Composite Amplifier 8.2.3.1 Design Requirements 8.2.3.2 Detailed Design Procedure 8.2.3.3 Application Curve 8.3 System Examples 8.3.1 Temperature Measurement Application 8.3.2 Single Operational Amplifier Bridge Amplifier Application 8.3.3 Low-Side Current Monitor Application 8.3.4 Other Applications 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 General Layout Guidelines 10.1.2 DFN Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Community Resources 11.5 Trademarks 11.6 Electrostatic Discharge Caution 11.7 Glossary 12 Mechanical, Packaging, and Orderable Information
