SN74AHC8541 8-BIT INVERTING/NONINVERTING SCHMITT-TRIGGER BUFFERS W/3-STATE OUT datasheet (Texas Instruments) - 5
Описание8-bit Inverting/Non-Inverting Schmitt-Trigger Buffer With 3-state Outputs
Страниц / Страница8 / 5 — SN74AHC8541. www.ti.com. NOISE CHARACTERISTICS(1). PARAMETER. MIN. TYP. …
Формат / Размер файлаPDF / 363 Кб
SN74AHC8541. www.ti.com. NOISE CHARACTERISTICS(1). PARAMETER. MIN. TYP. MAX. UNIT. PARAMETER MEASUREMENT INFORMATION
SN74AHC8541 www.ti.com NOISE CHARACTERISTICS(1) PARAMETER MIN TYP MAX UNIT PARAMETER MEASUREMENT INFORMATION
... SCLS716 – APRIL 2009
VCC = 5 V, CL = 50 pF, TA = –40°C to 85°C
VOL(P) Quiet output, maximum dynamic VOL 0.4 V VOL(V) Quiet output, minimum dynamic VOL –0.4 V VOH(V) Quiet output, minimum dynamic VOH 4.5 V VIH(D) High-level dynamic input voltage 3.5 V VIL(D) Low--level dynamic input voltage 1.5 V (1) Characteristics are for surface-mount packages only.
A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr ≤ 3 ns, tf ≤3 ns. D. The outputs are measured one at a time with one transition per measurement. E. tPZL and tPZH are the same as ten. F. tPLZ and tPHZ are the same as tdis. G. tPLH and tPHL are the same as tpd.
Figure 1. Load Circuit and Voltage Waveforms
Copyright © 2009, Texas Instruments Incorporated Submit Documentation Feedback 5 Product Folder Link(s): SN74AHC8541 Document Outline FEATURES DESCRIPTION ABSOLUTE MAXIMUM RATINGS RECOMMENDED OPERATING CONDITIONS ELECTRICAL CHARACTERISTICS SWITCHING CHARACTERISTICS SWITCHING CHARACTERISTICS NOISE CHARACTERISTICS PARAMETER MEASUREMENT INFORMATION
