The Microchip Technology MCP6281/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current. This family has a 5 MHz Gain Bandwidth Product (GBWP) and a 65° phase margin. This family also operates from a single ...
Семейство операционных усилителей (ОУ) Microchip Technology MCP6281/1R/2/3/4/5 обеспечивает широкую полосу пропускания тока. Это семейство имеет коэффициент усиления полосы пропускания 5 МГц (GBWP) и запас по фазе 65°. Это семейство также работает ...
The Microchip’s MCP6481/2/4 family of operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation. This family is unity gain stable and has a gain bandwidth product of 4 MHz ...
The Microchip’s MCP6481 operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation. This family is unity gain stable and has a gain bandwidth product of 4 MHz (typical). These ...
Rail-to-rail output, operational amplifier in Teeny™ SC70 packaging. The MIC860 provides 4MHz gain-bandwidth product while consuming an incredibly low 30µA supply current. The SC70 packaging achieves significant board space savings over devices ...
The MCP6286 operational amplifier offers low noise, low power and rail-to-rail output operation. This combination of features makes this product well suited for single supply, low noise, battery-powered applications. The MCP6286 operational ...
Dual low-power operational amplifier in an SOT23-8 package. It is designed to operate in the 2V to 5V range, rail-to-rail output, with input common-mode to ground. The MIC862 provides 3MHz gain-bandwidth product while consuming only a 31μA/channel ...
The MCP604 quad operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230uA. The MCP604 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high ...
The MCP602 dual operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV. The MCP602 uses Microchip's advanced CMOS technology, which provides ...
MCP603 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 and an offset voltage that is less than 2 mV. The MCP603 uses Microchip's advanced CMOS technology, which provides low bias ...
Операционный усилитель MCP601 (ОУ) имеет полосу усиления 2,8 МГц с низким типичным рабочим током 230 мкА и напряжением смещения менее 2 мВ. В MCP601 используется передовая КМОП-технология Microchip, которая обеспечивает низкий ток смещения, ...
Счетверенный операционный усилитель MCP6L4 (ОУ) имеет полосу усиления 2,8 МГц с низким типичным рабочим током 200 Ом. В MCP6L4 используется передовая КМОП-технология Microchip, которая обеспечивает низкий ток смещения, высокую скорость работы, ...
Сдвоенный операционный усилитель (ОУ) MCP6L2 имеет полосу усиления 2,8 МГц с низким типичным рабочим током 200 В и напряжением смещения менее 3 мВ. В MCP6L2 используется усовершенствованная КМОП-технология Microchip, которая обеспечивает низкий ток ...
Операционный усилитель MCP6L1R (ОУ) имеет полосу усиления 2,8 МГц, низкий типичный рабочий ток 200 мкА и напряжение смещения 1 мВ (типовое). В MCP6L1R используется передовая КМОП-технология Microchip, которая обеспечивает низкий ток смещения, ...
Операционный усилитель MCP6L1 (ОУ) имеет полосу усиления 2,8 МГц, типичный низкий рабочий ток 200 мкА и напряжение смещения 1 мВ (типовое). В MCP6L1 используется передовая КМОП-технология Microchip, которая обеспечивает низкий ток смещения, ...
Microchip’s MCP6H71/2/4 family of operational amplifiers (op amps) has a wide supply voltage range of 3.5V to 12V and rail-to-rail output operation. This family is unity gain stable and has a gain bandwidth product of 2.7 MHz (typical). These ...
