Datasheets - DC/DC преобразователи и контроллеры Microchip - 7
Подраздел: "DC/DC преобразователи и контроллеры"
Производитель: "Microchip"
Найдено: 163 Вывод: 121-140
Вид: Список / Картинки
  1. The MIC2290 is a 1
  2. The MIC2288 is a 1
  1. The MIC2253 is a high power density 1MHz PWM DC/DC boost regulator
  2. The MIC2251 is a general purpose DC/DC boost switching regulator that features low noise, EMI reduction circuitry, and high efficiency across a wide output current range
  1. The MIC2250 is a general purpose DC/DC boost switching regulator that features low noise, EMI reduction circuitry, and high efficiency across a wide output current range
  2. The MIC2172 and MIC3172 are complete 100kHz SMPS current-mode controllers with internal 65V 1
  3. The MIC2171 is a complete 100kHz SMPS current-mode controller with an internal 65V 2
  4. The MIC2145 is a small size boost switching regulator that can provide over 2
  5. The MIC2141 is a micropower boost switching regulator that can operate from 3- or 4-cell nickel-metal-hydride batteries or a single Li-Ion cell
  6. The MCP1665 device is a compact, high-efficiency, fixed-frequency, non-synchronous step-up DC-DC converter that integrates a 36V, 100 mΩ NMOS switch
  7. The MCP1664 device is a compact, space-efficient, fixed-frequency, non-synchronous step-up converter optimized to drive LED strings with constant current from two and three-cell alkaline and NiMH/NiCd or one-cell Li-Ion or Li-Polymer batteries
  8. The MCP1663 device is a compact, high-efficiency, fixed-frequency, non-synchronous step-up DC-DCconverter which integrates a 36V, 400 mΩ NMOS switch
  9. The MCP1662 device is a compact, space-efficient, fixed-frequency, non-synchronous step-up converter optimized to drive LED strings with constant current from two and three-cell alkaline and NiMH/NiCd or one-cell Li-Ion or Li-Polymer batteries
  10. The MCP1661 device is a compact, high-efficiency, fixed-frequency, non-synchronous step-up DC-DCconverter which integrates a 36V, 800 mΩ NMOS switch
  11. The MIC2877 is a compact and highly efficient 2MHz synchronous boost regulator with a 6
  12. The MIC2876 is a compact and highly-efficient 2MHz synchronous boost regulator with a 4
  13. The MIC2875 is a compact and highly-efficient 2MHz synchronous boost regulator with a 4
  14. MCP1643 is a compact, high-efficiency, fixed frequency, synchronous step-up LED driver with constant current, that operates from one and two-cell alkaline and NiMH/NiCd batteries
  15. The MCP1642B/D is a compact, high-efficiency, fixed frequency, synchronous step-up DC-DC converter
  16. The MCP1640/40B/40C/40D is a compact, high-efficiency, fixed frequency, synchronous step-up DC-DC converter
