Datasheets - Контроллеры и драйверы двигателей / движения / зажигания - 7
Подраздел: "Контроллеры и драйверы двигателей / движения / зажигания"
Найдено: 872 Вывод: 121-140
Вид: Список / Картинки
  1. The IFX007T is an integrated high current half bridge for motor drive applications. It is part of the Industrial Multi Purpose NovalithIC family containing one p-channel high-side MOSFET and one n-channel low-side MOSFET with an integrated driver ...
  2. The IFX007T is an integrated high current half bridge for motor drive applications. It is part of the Industrial Multi Purpose NovalithIC family containing one p-channel high-side MOSFET and one n-channel low-side MOSFET with an integrated driver ...
  1. Datasheet Infineon IM818MCCXKMA1
    CIPOSTM MaxiIntelligent Power Module 3-phase inverter topology in a Dual In-Line molded package, with 1200 V, 10 A voltage rating, targeting up to 1.5 kW power rating.
  2. CIPOSTM MaxiIntelligent Power Module 3-phase inverter topology in a Dual In-Line molded package, with 1200 V, 10 A voltage rating, targeting up to 1.5 kW power rating.
  1. Datasheet Infineon IM818SCCXKMA1
    CIPOSTM Maxi Intelligent Power Module 3-phase inverter topology in a Dual In-Line molded package, with 1200 V, 5 A voltage rating, targeting up to 750 W power rating.
  2. CIPOSTM Maxi Intelligent Power Module 3-phase inverter topology in a Dual In-Line molded package, with 1200 V, 5 A voltage rating, targeting up to 750 W power rating.
  3. Datasheet Asahi Kasei Microdevices AP1050AEN
    Pre-Driver IC for 3-Phase Brushless Motor The AP1050 is a pre-driver for a 3-phase brushless motor with built-in power supplies, which operates motor drive voltage in range of 8V to 36V. It incorporates a step-down DC-DC converter and LDOs to ...
  4. Pre-Driver IC for 3-Phase Brushless Motor The AP1050 is a pre-driver for a 3-phase brushless motor with built-in power supplies, which operates motor drive voltage in range of 8V to 36V. It incorporates a step-down DC-DC converter and LDOs to ...
  5. Datasheet TRINAMIC TMC2160-TA
    High-power stepper motor driver IC with SPI interface and external MOSFETs for up to 20A motor current per coil
  6. High-power stepper motor driver IC with SPI interface and external MOSFETs for up to 20A motor current per coil
  7. 3 function modes (CW / CCW / STOP) / PWM control. Brush motor driver IC
  8. Power Application Controller
  9. Power Application Controller
  10. Full, Half, Quarter, 1/8, 1/16, 1/32, 1/64, 1/128 step resolution / Active Gain Control / RS less control / Advanced Dynamic Mixed Decay / Selectable Mixed Decay. Stepping motor driver IC
  11. Datasheet TRINAMIC TMC8670-BI
    EtherCAT Motion Controller for 2-/3-Phase PMSM The TMC8670 is a single-axis servo motor controller for industrial automation, embedded servo control and other automated equipment applications. It is suitable for 3-phase BLDC and 2-phase stepper ...
  12. EtherCAT Motion Controller for 2-/3-Phase PMSM The TMC8670 is a single-axis servo motor controller for industrial automation, embedded servo control and other automated equipment applications. It is suitable for 3-phase BLDC and 2-phase stepper ...
  13. 500mA BLDC Motor Controller
  14. 500mA BLDC Motor Controller
  15. 72V Brushless Motor Gate Driver with 16bit CPU
  16. 72V Brushless Motor Gate Driver with 16bit CPU
