PNP Bipolar Small Signal Transistor The PNP Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the TO-92 package, which is designed for medium power applications.
PNP Bipolar Transistor The PNP Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the TO-92 package, which is designed for medium power applications.
NPN Bipolar Small Signal Transistor The PNP Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the TO-92 package, which is designed for medium power applications.
NPN General Purpose Amplifier NPN General Purpose Amplifier This device is designed for general purpose amplifier applications at collector currents to 300 mA. Sourced from Process 33.
Dual General Purpose Transistors The Dual PNP Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-363/SC-88, which is designed for low power surface mount applications.
Dual PNP Bipolar Transistor The Dual PNP Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-363/SC-88, which is designed for low power surface mount applications.
PNP Bipolar Transistor The PNP Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-23 package, which is designed for lower power surface mount applications.
Биполярный транзистор PNP предназначен для использования в линейных и переключающих приложениях. Устройство размещено в корпусе SOT-23, который предназначен для поверхностного монтажа с низким энергопотреблением.
Двойной биполярный транзистор NPN Двойной биполярный транзистор NPN предназначен для усилителей общего назначения. Он установлен в корпусе SOT-363/SC-88, предназначенном для маломощного поверхностного монтажа.
NPN Bipolar Transistor The NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SC¿75/SOT¿416 package, which is designed for low power surface mount applications.
NPN Bipolar Transistor The NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-323/SC-70 package, which is designed for low power surface mount applications.
NPN Bipolar Transistor The NPN Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-23 package, which is designed for lower power surface mount applications.
Биполярный транзистор NPN предназначен для использования в линейных и переключающих приложениях. Устройство размещено в корпусе SOT-23, который предназначен для поверхностного монтажа с низким энергопотреблением.
