Datasheets - Биполярные транзисторы ON Semiconductor - 6
Подраздел: "Биполярные транзисторы"
Производитель: "ON Semiconductor"
Найдено: 555 Вывод: 101-120
Вид: Список / Картинки
  1. NPN Bipolar Transistor The NPN Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-23 package, which is designed for lower power surface mount applications.
  2. NPN Bipolar Transistor The NPN Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-23 package, which is designed for lower power surface mount applications.
  2. NPN Bipolar Transistor The NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-323/SC-70 package, which is designed for low power surface mount applications.
  1. Биполярный транзистор NPN предназначен для использования в линейных и переключающих приложениях. Устройство размещено в корпусе SOT-23, который предназначен для поверхностного монтажа с низким энергопотреблением.
  3. NPN Bipolar Transistor The NPN Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-23 package, which is designed for lower power surface mount applications.
  4. Dual NPN Bipolar Transistor The Dual NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-363/SC-88, which is designed for low power surface mount applications.
  5. Dual NPN Bipolar Transistor The Dual NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-363/SC-88, which is designed for low power surface mount applications.
  6. Dual NPN Bipolar Transistor The Dual NPN Bipolar Transistor is designed for general purpose amplifier applications. It is housed in the SOT-363/SC-88/SC70-6, which is designed for low power surface mount applications.
  7. PNP Bipolar Transistor The PNP Bipolar Transistor is designed for use as a general purpose amplifier and in switching applications. The device is housed in the SOT-223 package which is designed for medium power surface mount applications.
  8. General Purpose Transistor PNP Silicon PNP Silicon
  9. 60 V PNP General-Purpose Transistor The PN2907A, MMBT2907A, and PZT2907A are 60 V PNP bipolar transistors designed for use as a general-purpose amplifier or switch in applications that require up to 500 mA. Offered in an ultra-small surface-mount ...
  10. NPN Bipolar Transistor The NPN Bipolar Transistor is designed for use in linear and switching applications. The device is housed in the SOT-223 package, which is designed for medium power surface mount applications.
  11. (Legacy Fairchild) NPN General Purpose Amplifier NPN General Purpose Amplifier This device is for use as a medium power amplifier and switch requiring collector currents up to 500 mA. Sourced from Process 19.
  12. PNP Bipolar Transistor
  13. PNP Bipolar Transistor
  14. PNP Bipolar Transistor
  15. Amplifier Transistors
  16. p-n-p биполярный транзистор
